Question for you guys???
Old 12-02-2009, 07:47 PM
1CL3ANSUP3RSPORT's Avatar
Question Question for you guys???
well just put 22000 on the imp,which isnt too bad for an 08.Now my question is has anyone had trouble,with a trans leak by the driver side wheel???Or a rear main seal leak,I looked under my car today when getting my tires balance.And I notice fresh oil and tranny fluid,guess it might be time to take here back into the stealership b4 the HEADERS ARE READY... Any info would be greatly appricated,thanks
Dom
Old 12-02-2009, 08:37 PM
Mels SS's Avatar
Are you sure its tranny fluid. it could be the oil pan drain plug o ring leaking
Old 12-03-2009, 07:12 AM
bdyman's Avatar
if i remember right i think there is a tsb out for the oil pan or the rear main seal not to sure but i do remember a tsb is out there for a oil leak
Old 12-03-2009, 09:28 AM
Yeah pretty sure its tranny fluid mel,it is a red fluid.ill have to check into the o ring as well,atr first I thought maybe I didn't tighten up the oil filter.but it was tight as hell when I check,at break time ill check to see where my fluids are,and ill see how bad the leak...
Might be a dumb question,that stuff should be covered by warrenty???Right???
Alright ill have to check into that bdyman,what about the the tranny leak???when I looked under the car it was on the driver side by the wheel,could the I shaft be goin out or the bearing inside.which is causing it to leak???
Old 12-03-2009, 09:32 PM
Ls4GXP's Avatar
I had the same problem, if you look in your engine bay driver side bottom you will notice
that there are two transmission lines running together side by side to the air trans cooler next to the radiator....its simple the two trans line rubbed themselves out one or the other broke out fluid first, so I would recommend you buy both new ones and when installed make sure that they are separated just enough so that they do not rub.....its one the flaws that GM did with these LS4s and there prone to leakage, I recommend everyone that reads this and has an LS4 to check this and pull those tranny cooler lines apart so they do not rub.
Old 12-04-2009, 06:43 AM
Ls4GXP thanks ill have to look at that as well,if you could provide a pic of both line I would appricate it...
Dom
Old 12-04-2009, 04:55 PM
Quicklynx's Avatar
let us know what the issue ends up being sleeper
Old 12-04-2009, 05:51 PM
Sittingmongoose's Avatar
should be covered under warrenty, your not very modded so i dont see an issue with that.
Old 12-04-2009, 08:27 PM
Gonna take her in on Monday,and the service manager I talk to is koo.He actually like what did to the imp already,and since I came from another Chevy dealer and brought my business to him(Master cylinder and other brake **** mine and the wifes cars).I think i on good terms,lol!!!
Sooo I think!!!
Old 12-09-2009, 08:35 PM
Well found out today that the oil pan gasket is where my oil leak problem is,but as for my tranny leak there gonna run a dye thru the system to see where the leak is coming from.On a side note,im gettin all warrenty work done on the impy passenger seat makes a funny noise when someone sits on it and the passenger side front seat belt wont engage...Should have my car back by friday
Old 12-11-2009, 08:51 PM
Just got her back today and didnt have to pay for ****,man i love that warrenty thing lol...The trans leak came from a messed up trans cooler line fitting...got my passenger seat fix as well and just waiting for my new seat beat which will be here on wed next week...
thanks for the info Ls4GXP,you were almost right on the money!!!
Old 12-11-2009, 10:01 PM
CenTexSS's Avatar
Glad they took care of everything, I had my rear main replaced at 28k miles
Old 12-14-2009, 07:08 PM
damn that sucks,were you modded pretty heavy???And did the warrenty cover it??
