10.50 NA SBC + Spray
I am looking to build a 355 sbc that will run 10.50NA and maybe hit a high 9 with a 100-150 shot. I will hopefully be starting with a newly acquired low mile 78 Z/28. I have an old sbc sitting in the garage waiting for a good donor body. The current build was set up as a little street brawler to run 12's at the track. I never took it to the track after being built. That project got abandoned as I bought a house and a Grand National 8 years ago. Sold the 77 Camaro body and kept the motor for a future project. That future project may be now. I have been running the GN in the 11's for 3 years now but won't take it much further due to not putting a cage in it. I want the new build to go 9's & 10's. I would love to keep it a 4 spd car but my Muncie M21 can't continually take that kind of power so I plan to go with a TH350 properly built with a 3500-4000 stall with 4.11 gears and 33 spline mosers and Eaton posi.
The current motor has:
1970 010 4 Bolt Main Block bored 0.030
194cc heads with a lot of work done
Comp Cams 280Hyd Cam .480 lift 110lobe sep.
Stock Rods resized and conditioned/balanced
9.7 Compression with TRW forged pistons
750 Holley Vac/2nd & Edlebrock Performormer Intake
Intention is to throw a good forged crank in it w/ billet main caps. Go with some AFR210 heads and use my Harland Sharp Roller Rockers. Put a Victor or World Products single plane intake and MSD 6AL box. Maybe go with a Quick Fuel or Demon Carb. Throw a 100-150 shot plate on it. And an electric water pump.
Questions:
Is the 280 cam enough and nitrous friendly?(Never used NO2, turbos have been my great equilizer)
Will stock rods hold up to the abuse (everything is ARP wave loc bolts)?
Is the compression too low (w/1.94 heads) to get me there?
Will it be durable and streetable?
Any parts suggestion and experience are welcome and appreciated. Suspension mods and brakes will also be upgraded appropriately. I have been so into the Buicks for the last 8 years that I almost forgot the bore and stroke of the tried and true SBC.
Questions:
In-Zane Moderator
What you want will require a few things.
1 A really light car, 2500 lbs would be great
2 Deep gear and suspension
3 A solid roller with 13 to 1 compression with HUGE heads and all the expensive forged equipment to support the RPM
4 A really solid bad *** ignition to keep up
There is just not enough cubic inches to make it happen easier.
In reference to your comments that are appreciated.
Car weight will be roughly not be cut. So ~3300lbs. This is not a tube chasis build. It is a slightly modified 78 Z/28
How deep of a gear? 4.56 or steeper?
Solid Roller cam above 13:1? Steetability declines quickly for pump gas driving. No problem going solid or roller cam set up though. AFR210 aren't good enough? Suspension will be addressed.
What ignition system are you sugeesting?
Should I go a stroker motor for cubes?
Thanks
Barry
In-Zane Moderator
650 HP would be required to go 10.50 in the 1/4, so all the above i mentioned is required to get it there.
Your turbo car is working on a power adder VS N/A, so it is a straight advantage. The torque numbers are thru the roof too.
If you can do a stroker, you will need less RPM to make the power, then you can sacrifice things as such high compression. A 383 can make 550 HP on 93 octane, but the extra 100 H will need more cubes or once again, high compression losing the ability to run pump gas.
Really? A sbc is that difficult to get a sub 10.50 time slip? I can change my turbo and upgrade the tranny in my GN and go 10.50 all day the way it sits.
Thanks
Barry
Thanks
Barry
I happen to be thinking of selling my motor to switch to a LSX setup. Which may be exactly what your looking for. Pm if your interested I can shoot you all the details. Good luck with your set up!
no its not difficult to make a sbc go 10.50 in a decent weight car .Your just talking to the wrong ppl (aka LSx is the only way crowd). Look into 18/15/12 and some 23 degree(all pro, brodix ,dart) cylinderheads. i would suggest talking to local speed/machine shops.
Have a custom cam ground for it. Shelf stuff sucks in my opinion.
My junk goes 7.50 on motor, but 6.1 on a 150 shot. 3000lb car.
377, untouched 215cc Iron Eagles, 13:1, Super Victor, Pro Systems 4150 carb, 1-3/4 headers.
A 1979 Z28 is going to be a 3700 to 3800lb car; way too heavy to push into the 10's with a 350 that isn't going to be reved to 8,000rpm. If the car weighed 3,200 and you stuck in a 550hp 406, then you would be in the ballpark.
BTW, the parts you mention are not even going to crack 400hp in a 350.
To the OP, go check out the forums on yellowbullet.com. You'll find much better info on sbc stuff than you will on an lsx dominated site.
Well I will find out Monday of I am getting the car. For the moment, I am just going to add a 150 shot to the my 355 and put a forged crank in it. I will also do the rear suspension, tie the frame and take care of disc brakes in the rear. In the meantime I think I will look for a 454 to build up. I will just run the SBC while the build is being done. The car will be street driven and raced so durability is important. I know I can get the small block in the 10's NA given I have 2 buddies that have achieved it (1 goes 9.90NA w/23` heads)
You are probably right but the cast crank in it now was turned 10/10 but at the upper limits of the specs. When the crank wore in after break in, it was out and I began losing oil pressure when I revved the motor. I would rather go forged now for the fact that I like a stout bottom end. Better rods at a later time if more power is in the sbc future.
Goodluck, nice to hear you have a plan for the SBC and better future plans.
I've seen stock rods/crank go FAR beyond what GM intended them for. Well into the single digits in heavy heavy cars. I've also seen stock rods bend with head/cam LT1 engines with 150+ shots.. What makes them live? I dont know!! If you get a steal of a deal on a crank, some Scat I-beams with 7/16" bolts are a nice investment and a cheap compliment to a forged crank.
You have to take this forum as any... with a big grain of salt.
Zone... 2500lbs? 13:1? Why not 15:1? WTF is a solid bad *** ignition? Are these the tricks that got you in the 10's??
