top fuel dyno?
top fuel dyno?
does anyone know how or if they ever have dynoed a top fuel car whether it be chassis or engine dyno. how do they know they make 8000 hp i cant find any info on this. -tony-
they run over 300 mph in the 1/4 and hurt youre ears so i would say yeah they make that much but have no proof
besides the fact that they shake the ground and every inch of youre body when they go by. nitro is a gift from the gods
i believe its based off of the sensors around the clutch that can measure torque, there is no dyno in the world that can measure the power of these beasts....nitro is such a beautiful thing....
hmm that makes sense, sensors on the car possibly.thats what i was kinda figuring also just a mathematical guestimate. but when the engine builder builds it i wonder if they put it on an engine dyno just to tune it but clearly not full throttle it.(the first initial build, not the rebuild they do between every race).
Imagine this video times 100. That's what you can imagine a top fuel car would be like on a chassis dyno, that is if they could make one that could measure that much power. (Which they don't.)
http://www.youtube.com/watch?v=-Jkwt...eature=related
6 & 8 Second Club
A while ago they were trying to build a fuel motor dyno. I believe Kenny Bernstein was footing the bill.
I believe they were trying to use parts or designs from giant ocean type engines.
Don't remember how far it got or who exactly was building it.
Maybe someone a lot smarter than me can figure out how to google the articles??
As for the 8000 HP, it is a estimate using all of the information available.
ET, MPH, fuel used, difference between 8 cylinders and 7 cylinders pass, data recorder ect ect.
Most probably know that hp is a calculation. Not measured. They need to find torque because h is torque vs. Time. There still isn't a dyno to measure that torque! I am sure it is mathematical equations but I am sure it is rather accurate.
Fuel usage is a very accurate way to measure hp. I don't know the science but energy released from fuel equals hp. Then they calculate losses from friction and what not. I would say if you could dyno the motor they are within 500 hp of the calculated value.
It mathematical of course.Just look at the FACTS.A fuel car accelerates from the 1/8 mile mark 660 ft to the old 1/4 mile mark in 1.5 seconds and goes from 275 to 325, 50 mph increase in 1.5 seconds.Im not a mathematician,but im sure this is somewhat how it is figured.
actually they measure the exact amount of torque produced by using a strain gauge on the shaft to the rear end.When you know the makep of the shaft you can calculate how much torque it takes to twist it a certain amount.The strain gauge measures the amount of twist,giving you the amount of torque produced.This is a really accurate way of measuring torque-we use it quite often to measure prop curves in boats.
dfddf
, but you can measure force, distance, and time.
