Quiet the Rear End- How?
Old 12-05-2009, 04:33 PM
danbrazda's Avatar
Default Quiet the Rear End- How?
4.10 gears in reinforced 10-bolt. Very whiney. Had it checked by performance shop and was told it is in great shape and that is just the nature of the beast. GM Motive gears. Performs flawlessly but I'm just wondering if there are any ways to quiet the decibals making it to my ears inside.
Old 12-05-2009, 08:06 PM
thesource's Avatar
Motive Gears = JUNK
Even oem GM gears in that low of a ratio will make noise most of the time especially once you run slicks on the car. I use to set up diffs and the GM 7.5 10 bolt is damn hard to set up quiet. Keeping it quiet is even harder.
Old 12-05-2009, 08:18 PM
Fade2blk500's Avatar
The only gears i've EVER had luck with is the gm MOTIVE gears. I used the motive 4.10's in my moms ws6 and they are quiet as a mouse.. Is it whining under decel or accel??
Old 12-05-2009, 08:31 PM
kyles2000z's Avatar
ear plugs
Old 12-05-2009, 08:56 PM
danbrazda's Avatar
Most of the noise is decel. Backlash?
Old 12-06-2009, 08:14 AM
BADD SS's Avatar
I think the ten bolt is your biggest issue.... It doesnt like the 4.10's or abuse.....
I have motives in my 9", quiet as a mouse after almost 40 passes on the car this year leaving at 6500 +rpm on slicks....
Old 12-06-2009, 10:11 AM
MY99TAWS6's Avatar
Had 4.10 gm motives in my 97 Ta. No track runs but was really quiet ,had them in for maybe 10,000 miles. Moved them into my 99 ta and they were super noisy. Reinstalled them should maybe have swapped carrier but it wasn't possible as sold them when traded in car with it and then got them back from guy that bought car.
Tried richmond 3.73 ,even more horrible. Gave up and went back to stock.Now have dana 60.
Factory gm gears are quietest but to keep them quiet is hard with the piece of crap 10 bolt. I think it just lets things go off spec the more you hammer on it.
Old 12-06-2009, 03:51 PM
In-Zane Moderator
ZONES89RS's Avatar
You fix it with a 12 bolt/9"/D60.
Old 12-06-2009, 03:53 PM
99FormulaM6's Avatar
^^not necessarily.. my 12 bolt was noisy as hell
Old 12-06-2009, 04:10 PM
In-Zane Moderator
ZONES89RS's Avatar
Any rearend can be noisy.
Old 12-06-2009, 05:29 PM
Yes, I realize that. I was merely commenting on your comment that said buying a 12 bolt/9"/D60 would fix it..
Old 12-06-2009, 05:33 PM
In-Zane Moderator
ZONES89RS's Avatar
My Moser 12 is pretty quiet, i have 4.30 gears.
Old 12-06-2009, 06:00 PM
danbrazda's Avatar
Thanks for all the replies guys but to be honest I'm even more perplexed now. Not just on this board but others, as well as talking to dozens of Pros, I hear the same contrasting remarks-
-GM Motive 4.10s are the best & Quietest
-GM Motive 4.10s are the worst and loudest
-Richmond 4.10s are horribly loud
-Richmond 4.10s are quieter than GM Motives
-10 Bolt rearend is junk
-12 bolt rearend is the best
-9" is the best
-10 bolt reinforced is just fine if you setup the gears right
So, where I am at this point is: My 2001 WS6 puts out 450rwhp through GM Motive 4.10s and stock rear with reinforced girdle. I will not be running the car on slicks- only on the street (and not racing it there either- just spirited jaunts when I get the itch). I love the 4.10s in every way except for the fact that they are so damned loud and whiney.
When I stumble on the 3-5K to put a 12-bolt or 9" in I will do it. Until then- is there ANYTHING at all that I can do to lessen the noise? Bottom line- is it backlash that I am hearing or some derivation thereof or is it simply the nature of the beast with my setup? Thanks again in advance all.
Old 12-06-2009, 06:39 PM
kyles2000z's Avatar
its bc everyone takes their personal experience, and makes generalities based on those, without any regard to how things were installed. i still thing earplugs are your best bet!
Old 12-06-2009, 07:19 PM
danbrazda's Avatar
Or the Monsoon Stereo!
Old 12-06-2009, 07:52 PM
In-Zane Moderator
ZONES89RS's Avatar
I paid 1500$ for my Moser 12 bolt, just save for a good used one like i did.
Old 12-06-2009, 08:08 PM
danbrazda's Avatar
$1500!!! Where did you get that deal? I thought I was looking at 3K plus.
Old 12-07-2009, 08:30 AM
In-Zane Moderator
ZONES89RS's Avatar
You are looking at 2500$ up if i remember correct, i got mine used. It is what they go for usually unless they have nearly no miles on them.1500-2000$ used.
Old 12-07-2009, 09:33 PM
Ironxcross's Avatar
get a different set of gears. noise usually means they aren't set up correctly.
I had 4.11 gears in my 9". The thing whined like a banshee. Why? It wasn't set up right.
I've had my factory rear apart several times. It's quiet. Why? Set up right.
Unless you want to deal with the noise (cheapest option), look into getting it adjusted.
Old 12-07-2009, 11:30 PM
disc0monkey's Avatar
Originally Posted by ironxcross
get a different set of gears. Noise usually means they aren't set up correctly.
++++++1
Quick Reply: Quiet the Rear End- How?
