does LS6 valley cover fit on 06 LQ9 with out block clearancing?
Old 12-05-2009, 06:37 PM
MBC Racing's Avatar
Default does LS6 valley cover fit on 06 LQ9 with out block clearancing?
I have the ls6 valley cover from my old motor and remember that the 00 ls1block had to be clearance to get it to fit. I want to know if it will fit on my 06' LQ9 motor before I take the stock valley cover off. I would rather not take it appart and have to get a new gasket if it isn't going to fit with out grinding the block.
Thanks!
Old 12-05-2009, 06:46 PM
xdanny510x's Avatar
i believe they do..
Old 12-05-2009, 08:44 PM
Randy WS6's Avatar
I dont believe the LS6 valley cover will work, because of the oil sending unit placement
Old 12-05-2009, 09:13 PM
MBC Racing's Avatar
on the 5.7 motor I have, I had to grind a part of the block that was interfering with the baffle in the cover. There were no issues on the outside of the motor. There was a rib inside, under the cover.
Old 06-25-2010, 04:15 PM
mushroom281's Avatar
Yes they do. I just bolted one on mine no problem
Old 06-26-2010, 10:58 AM
sparkwirez06's Avatar
i have a 04 6.0 block, fit fine.
Old 06-27-2010, 09:16 AM
99LSS1's Avatar
Thanks!
It should fit just fine. Also, No need to buy a new gasket, You can re-use the old one if it is in good shape!!!
Old 06-28-2010, 09:30 AM
Jon@Texas-Speed's Avatar
It should bolt up without an issue. Obviously, if the baffle is hitting something you need to clearance it but I haven't run into that issue w/ an LS1 or LS6 cover here.
Jon
Quick Reply: does LS6 valley cover fit on 06 LQ9 with out block clearancing?
