Newb First Valvespring/Camshaft Install
Old 12-06-2009, 01:10 AM
69ChBuLQ4's Avatar
Default Newb First Valvespring/Camshaft Install
Installing an ls1 hotcam kit /w the ls6 valvesprings in a 2005 lq4 6.0l truck motor. The ls6 springs came with some valve seats that are different from the lq4 ones I have. The ones in my engine contain the seal while the ls6 ones have a separate seat and seal (seal not included). From taking some quick measurements, I think that the installed height of the spring will be the same with either seat (around 1.805 and the install height spring recommendation is 1.801). Does that mean I can just use the stock seats I have, swap the ls6 springs in without any shims and call it good? Anyone know where to find stock valvespring installed heights for the 05 lq4 to back up the measurements i took?
I really appreciate the help!
Old 12-10-2009, 09:38 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
You can run either style seat/seal with those springs. If yours are in good shape and not leaking, you can rock them. If they are questionable, go ahead and replace them
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-12-2009, 11:43 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Why not replace it so it new?
Old 12-13-2009, 10:39 AM
dgcustomz's Avatar
^x2. Just replace them. Everything looks nice right now but after it starts smoking on start ups it's gonna be a pain in the *** to swap afterwards. Just my 2 cents.
Old 12-25-2009, 02:40 PM
69ChBuLQ4's Avatar
The new seats for the springs look like they need a separate oil seal which I would have to order. The engine has 60k on it but the original oil seats look fine to me.
Old 01-06-2010, 12:01 AM
9Green-Z8's Avatar
i have a question what do i do if im swapping springs and my valve fell down help please
Old 01-06-2010, 12:24 AM
mayerichm's Avatar
Pull the head. You may be able to get it up with compressed air if the retainer groove is still upwards of the seal but i probably wouldnt risk it.
Old 01-06-2010, 12:39 AM
9Green-Z8's Avatar
i had it up with air but when i was putting the seal on the valve it went down its all the way in there sorry dont mean to hijack the thread im just really worried
Old 01-06-2010, 12:45 AM
mayerichm's Avatar
unless you have a real small telescoping magnet i'd say your gonna have to pull the head then go back with air. is the intake off already?
Old 01-06-2010, 01:07 AM
9Green-Z8's Avatar
no the intake is not off
Old 01-06-2010, 01:08 AM
9Green-Z8's Avatar
is it hard to pull the heads off i have arp head bolts
Old 01-06-2010, 01:12 AM
badss_02's Avatar
No it's not that bad, just make sure you torque and degree in sequence... Why didn't you just make sure the piston was at tdc before you pulled the valve spring???
Old 01-06-2010, 01:37 AM
9Green-Z8's Avatar
they told me it was easier to just put air in but i guess i didnt have enough pressure and also i have a 98 how do i turn the crank, if i turn it do you think the valve will come up again?
Old 01-06-2010, 01:39 AM
9Green-Z8's Avatar
what is the best torque wrench to get well not the best i know the best will be to pricy something good for the money?
Old 01-06-2010, 02:00 AM
badss_02's Avatar
No do not try to push it up if it has fallen in the cylinder... You will most likely bend the valve, you will need a new head gasket also... In the future it is much easier to do the tdc method. This is the torque wrench i use (the third one) http://www.sears.com/shc/s/search_10...+wrench&vName=
When doing the heads you will also need to degree the bolts, draw a horizontal line across the head of the bolt with a sharpie and use that mark to judge what degree you are at...
Old 01-07-2010, 12:22 AM
9Green-Z8's Avatar
even if they are ARP bolts
Old 01-07-2010, 12:39 PM
badss_02's Avatar
yessir
Old 01-07-2010, 01:30 PM
9Green-Z8's Avatar
so are the beam torque wrenches better then the microtek ones
Old 01-07-2010, 03:34 PM
ae13291's Avatar
^^^ remove the heads first, just go get a torque wrench, the main part is degreeing it
Old 01-07-2010, 04:32 PM
badss_02's Avatar
werd... Go to vatozone and rent one for a day. So much cheaper than buying one...
