V6 4L60e work on V8
Old 12-07-2009, 04:54 AM
1976CamaroGuy's Avatar
Default V6 4L60e work on V8
Hi,
I'm trying to find a 97-2004 4L60e to put on my 2004 5.3 V8 and I had a guy on craigslist said he had one.
But he said is was from a 2002 Blazer 2wd and the engine was a 3800 ?? I thought the Blazer was based on the S10 platforms and came with a 2.2 4cyl or a 4.3 V6
I have a 2000 s10 with a 2.2 4L60e and I know it won't work, but I thought the 3800 was found on FWD cars like the grand prix we used to own.
Either way, if it is a 4L60e from a 2002 S10 6 cylinder will it work on my 5.3 ?
I know the older 700r4 will bolt straight up to the 4.3 or SBC because the engines were essentially the same minus 2 cyl on the V6. Then you get into power handling issues if 4.3 tranny was bolted to a more powerful sbc.
Thanks!
Old 12-07-2009, 06:38 AM
I did some googling, if this guy's blazer is a 2002 it should have the 4.2 I6
Some of the quick searches I found said it would bolt to the 4L60e....could someone verify this?
Also if it does are the transmssions the same internally? I didn't want to get it bolted up and took a dump under the stock 5.3 engine.
This will be a retrofit into a 76 camaro BTW
Old 12-07-2009, 01:12 PM
cambirdracing's Avatar
I have a 700r4 that came from behind a 350 in a 90 truck. Needs to be rebuilt. I am in the houston area if you are down this way. Probably to much ship up there.
Old 12-10-2009, 01:32 AM
battsup's Avatar
I was wondering the same thing and i'm working on a similar project ('78 bird) and this is what i found
http://www.chevytalk.org/fusionbb/sh...hp?tid/193779/
Old 12-10-2009, 08:40 AM
malott's formula's Avatar
the 4l60e from a 4.3 v6 will work on a v8 but not any 3.4 or 3.8 wont fit a v8 and lt1/sbc and ls1 tranny wont work on eachother
Quick Reply: V6 4L60e work on V8
