4l60e fluid pressure question?
Old 12-07-2009, 06:35 PM
Black_Jack's Avatar
Exclamation 4l60e fluid pressure question?
i have a tranny im not sure if its good or not
i was wondering what would happen to the tranny if ur hooked the lines up backwards ?
would it cause the car to die at idle, an make tranny fluid come out the breather valve on the top of the case ?
and if it was driven like this for bout 10 miles or so u think the tranny would still be good ?
i opened it up the other night well took the pan off and the was no shavings in the pan or anything so what u think should i try putting it my car and see what happens or you think it would be a waste of time ?
Old 12-08-2009, 05:49 PM
Black_Jack's Avatar
so no 1 knows anything bout this or what ?
need help plz
Old 12-08-2009, 05:56 PM
01ssreda4's Avatar
The cooler lines? Well they would flow through the radiator in reverse but I cant see how that would physically harm the trans.....
Old 12-08-2009, 07:14 PM
Black_Jack's Avatar
yeah i have it running threw the stock and a aftermarket tranny cooler
u dont think that could build up pressure and maybe cause tranny fluid to some out the top breather valve or cause it to die at idle ?
Old 12-08-2009, 08:22 PM
01ssreda4's Avatar
I had mine run like that for a while and recently I switched to aftermarket cooler only. Im seeing cooler temps and its easier on the trans pump by not having to pump through 2 inline coolers.(factory and aftermarket) Im keeping mine like this from now on.
Old 12-10-2009, 03:35 PM
Black_Jack's Avatar
so did it cuase any problems like ive been having ? when u ran the both inline ?
Old 12-10-2009, 05:50 PM
01ssreda4's Avatar
Possibly increased pressure inside the trans, but I never verified that. My shifts were firmed up through HPTuners with increased line pressure. So obviously you dont want a restriction added along with already increased line pressures.
Old 12-12-2009, 05:43 PM
Black_Jack's Avatar
well what u think can cause these problems i had to happen if its not the cooler ?
Old 12-12-2009, 06:42 PM
jaycenk's Avatar
Do they flow fluid? thier not pluged right you can blow air through them?
Old 12-13-2009, 03:08 PM
Black_Jack's Avatar
im pretty sure there not pluged up but i cant check right now cuz there car is in storage i only have the trany at my house
Old 12-14-2009, 04:33 PM
Black_Jack's Avatar
so im guessing knows what can cause these problem in the 4l60e ?
Old 12-14-2009, 06:47 PM
LS1Tech Sponsor
performabuilt's Avatar
Pushing fluid out the vent is generally cause either by overfilling the trans or massivly overheating the trans Unless the cooler or radiator is blocked I doubt the arrangement would cause it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-14-2009, 07:35 PM
Black_Jack's Avatar
hmm that makes since, cuase i had just put the motor back in and refilled the tranny and stuff maybe there was still some old tranny fluid left in it ? causing me to over fill it ?
well u think the tranny is still good ?
also would this cause the car to die at idle ?
Old 12-20-2009, 08:07 PM
Black_Jack's Avatar
t t t t
Old 01-10-2010, 01:35 PM
Black_Jack's Avatar
any ideas on y it would stall at idle ?
if my starter mount was breaking of as this all was happening would that cause the car to die at idle and eventually completely die when the starter broke of ?
because it is a major ground ?
Old 01-15-2010, 05:18 PM
Black_Jack's Avatar
any 1 ?
Old 01-15-2010, 05:46 PM
shtnfrds's Avatar
what does the trans dip stick say? you have looked at it right? like said before, if its overfilled that could very easily cause the problem, like wise being under filled maybe too? heating the fluid up alot more because there is low level in the trans.
Quick Reply: 4l60e fluid pressure question?
