Help me decide stall speed for my car!
I just picked up an ATF level 2 powerglide today for my lsx mustang notchback and need help picking a conv. The car will be mainly used as a track car but will see some hwy. miles. The motor is a bone stock 2000 ls1 that I'm putting a 76mm turbo on. I will be building a forged motor later on and would like to get a conv. that will work good for the stock motor and on the built motor. What rear gear ratio would be best for this set-up on a 26" slick for the 1/4 mile. If any more info is needed on my part feel free to ask, thanks.
"All Motor 9 Second club member"
I would have to recommend a Circle D Specialties 230mm for the set up you have. It's very efficient and will serve you well with the powerglide. The stall choice will have to be decided once the cam, gear, power options are chosen.
We run their 230mm in our quicker car that also runs a powerglide and it works great with both of our combos.
G/L
G/L
The tranny already has a trans brake. The car should weigh around 3000 with me in it, maybe a little less. The motor that I am using first is a bone stock ls1 cam and all. I want to get as much out of this combo as I can. Thanks again for the help.
LS1Tech Sponsor
We here at FTI have a lot of experience with turbo cars and powerglides. the converter i would recomend is an SSW series 9". Specifically designed for a turbo application as the converter has to be loose enough to spool but efficient enough to couple once it is spooled. give us a call at 1-866-726-8358 and I can explain the benifits of having a converter builder like us on your team!!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
