good set up???
Old 12-09-2009, 08:42 PM
linebacker50's Avatar
Default good set up???
ok my b-day is coming up on the 17th and im turning the big 1 8. so after many hours of convincing my parents to let me buy a cam they agreed. its a 01 T/A, A4 transmission, lid, bbk LT hearders, and a cut out. so this is the set up im thinking about getting. its the texas speed 228R 112 lsa. with 918 springs. by the way this is my DD when the sun decides to do its job and heat the earth here in Michigan. if there are any objections please let me know cuz i dont wanna **** up on somethin like this. thanks
Old 12-09-2009, 08:59 PM
jsteele90's Avatar
good cam selection but dont forget to add a stall and tranny cooler to that list as well. and upgraded pushrods, timing chain, oil pump, gaskets,bolts, and a TUNE. $$$$
Old 12-09-2009, 10:35 PM
LS1-NAVY's Avatar
it will be a fun street car but u will need all the things said above
Old 12-10-2009, 12:27 AM
transamfreak01's Avatar
yup... i would go with a yank ss3600. i love mine but wish i went bigger like a 3800 or 4000. ull need a trans cooler, and i would also do a ls6 ported oil pump and double roller chain. oh and also a pulley. youre already down there so i would do it all at the same time. whats your budget and goals for it?
Old 12-10-2009, 09:54 AM
01ssreda4's Avatar
You need a minimum of a 3200 to keep your car pulling out of the hole. 4k would be a much better matched combo.
Old 12-10-2009, 10:13 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
These guys above covered all the bases! That stall will definitely be a priority!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-10-2009, 10:42 AM
blue99fbody's Avatar
no need for a double roller on a cam only set up just do the ls2 chain
Old 12-10-2009, 08:21 PM
navyblueSS's Avatar
The 228R matched with a Yank 3600 stall will make for a very streetable combo and will run strong at the track. I ran that combo for 2 years. My car made 400 rwhp 375rwtq and ran a best of 11.66 @ 116 full weight on 17in. M/T Drag Radials.
Old 12-10-2009, 09:13 PM
desertLS1's Avatar
dont forget about Vengeance VRX4 and Futrals F13 cams..
Old 12-11-2009, 03:15 PM
are those parts you said such as the trans cooler then such is that needed or a good idea? thanks
Old 12-11-2009, 03:38 PM
one more thing. will this cam give a nice badass choppy cam sound? or no?
Old 12-11-2009, 04:12 PM
01ssreda4's Avatar
Trans cooler is mandatory....
Old 12-11-2009, 08:11 PM
deadmanTA's Avatar
A4 go with the 114 lsa. It still has a very choppy idle. I'm running this cam with a 4K stall. It has great mid range power.
