Drag Racing Tech
28x10.50x15 MT ET Street or 275/60/15 MT ET Street drag radial
Old 12-10-2009, 02:03 AM
c5formula's Avatar
Default 28x10.50x15 MT ET Street or 275/60/15 MT ET Street drag radial
im in need of a new set of rear tires and was wondering what you guys think i should go with. should i pick up a set of 28x10.50x15 MT ET streets or should i go with a set of 275/60/15 MT ET street drag radials?
i actually have the 275s laying around but i wanted to know whick one would work better or which one my car would run faster on MPH wise?? thanks a ton guys.
Old 12-10-2009, 08:30 AM
Tally TransAm's Avatar
i have all kinds of trouble hooking up on radials with my M6, personally i would go slicks.
Old 12-10-2009, 01:10 PM
c5formula's Avatar
yeah i had a set of 27" et streets on the car and they worked pretty well when warmed up at the drag strip. i just seem to remember someone telling me that the car would run faster on the radials?
Old 12-10-2009, 01:56 PM
brandoz28's Avatar
get the 11.5 et streets, they're measured section width, not tread width like an et drag
Old 12-10-2009, 05:09 PM
AgFormula02's Avatar
we have gone 1.24 60 feet on the 275 et street radial
Old 12-11-2009, 12:59 PM
c5formula's Avatar
wow i wish you were here to help me set up my car suspension lol.
Old 12-11-2009, 01:02 PM
c5formula's Avatar
what would that do for me? would those 11.5 fit on an 8" rim? was just curious on which tires my car would run faster (mph wise) on...
Old 12-11-2009, 03:07 PM
brandoz28's Avatar
they're gonna give you some more tread width, and yes they will fit on an 8 inch wheel
Old 12-12-2009, 01:00 AM
c5formula's Avatar
hmm i may have to look into this...
Old 12-13-2009, 11:47 AM
MikeG's Avatar
M6 = ET Streets
A4 = ET Street Radials
Old 12-13-2009, 12:09 PM
98blueSScamaro's Avatar
if your a M6 you will want a slick M/T 28x10.5x15-S As in stiff wall. But if you want to street drive The QTP's 27x9x15 i hear work well with a 10 wide rim or a 8. But I say M/T slick i street drive on them no problems here HAHAHA. And Whats your gear size????
Old 12-13-2009, 02:52 PM
c5formula's Avatar
well i would like to still drive it on the street with these sticky tires for weekend fun but i also want this thing to pull better than a 1.78 60foot and with me putting nitrous on the car soon my current 27" tire isnt gonna be tall enough.
oh and im on a 9" ford rear with 4.33 gears and a mini spool.
Old 12-16-2009, 03:34 PM
BlackWS666's Avatar
Originally Posted by MikeG
M6 = ET Streets
^^^ What he said!!!
Old 12-21-2009, 04:52 PM
StealthFormula's Avatar
M6 = ET Streets
I agree with this. With my experience using both tires the Radials are better suited for Auto's. From what I've seen the Slicks work much better than the Radials with the 6-speeds.
Old 12-24-2009, 10:13 PM
StreetSilverado's Avatar
The radial is "quicker", but if your M6 go with a slick.
I went to a 28x10.5 ET Drag and slowed just a little in the 1/8th but 60ft was better. I'm A4 BTW.
Old 12-26-2009, 08:30 PM
Camaro396's Avatar
Six speed = bias ply tire = ET Street
ET Streets do not come in 28x10.5, you will need 28x11.5 and they will fit fine on a 15x8-15x10 wheel.
Old 12-30-2009, 05:03 PM
fatboyzcamaro's Avatar
Default 29 11.5 15 hoosier
Would a this 29-11.5-15 hoosier quick time pro fit under my camaro.
Old 12-30-2009, 05:36 PM
I_Need_Land's Avatar
im not sure here but i see 6spd = slick, a4 = radial... i assume the m6 with slick works better on the street than a radial ? or is this TRACK ONLY?
Old 12-30-2009, 10:13 PM
c5formula's Avatar
that was gonna be my next question. which one would be better suited for the street et street or the radial for a 6 speed of course?
Quick Reply: 28x10.50x15 MT ET Street or 275/60/15 MT ET Street drag radial
