Can't find a good dished LS2 piston/rod combo(stock cubes)
Old 12-13-2009, 04:37 AM
Snyper's Avatar
Default Can't find a good dished LS2 piston/rod combo(stock cubes)
Maybe im not looking in the right area...but where can I find a good piston/rod combo for my LS2?? Mainly looking for a 4.005 since i was told going to a 370ci isn't exactly safe for these blocks and I want it to be able to maintain around 850whp....also using 317 heads.
Old 12-13-2009, 07:19 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Many of the sponsors over on the left can help you out. Bob from EPP comes to mind first.
Old 12-13-2009, 07:40 AM
Fireball's Avatar
4.010 is fine on a LS2. I ran 1400ish hp all of 2008 with zero issues. I pushed it closer to 1700hp in 2009 and the liner finally let go...
.0025 of extra meat wouldn't have saved it
Old 12-13-2009, 09:01 AM
Mr.Big's Avatar
several options to choose from... doing the same thing soon... close to stock cube LS2
Old 12-13-2009, 09:44 AM
G Engines's Avatar
If you run a longer rod such as a 6.125 there is quite a good selection of pistons out there scoggins caries a few different brands to select from. http://sdparts.com/catalog/ls-gen-ii...mblies/pistons
Old 12-13-2009, 11:38 AM
Snyper's Avatar
Everything I find is either 4.030 or for a 4.000 stroke.
Old 12-13-2009, 12:11 PM
black98ws6ta's Avatar
Do you have a specific brand you want? There are tons of 4.005 pistons out there for stock stroke.
Old 12-13-2009, 12:16 PM
Snyper's Avatar
Not really. Just something forged...either rod size is fine. Ive looked on all the big sites and found nothing..unless im an idiot.
Old 12-13-2009, 12:24 PM
http://www.wiseco.com/Catalogs/Automotive/Chevrolet.pdf
Old 12-13-2009, 03:07 PM
dudeman's Avatar
i use wiseco 4.005 pistons with eagle rods. i got the pistons from texas speed.
Old 12-13-2009, 05:18 PM
Snyper's Avatar
they don't list those on the website.
Old 12-13-2009, 06:10 PM
eviltwin_1987's Avatar
i bet if you call speed inc, texas speed, or epp they can find what you need
Old 12-13-2009, 06:38 PM
J&J Speed Shop's Avatar
What compression ratio or dish volume are you looking for?
Old 12-13-2009, 09:43 PM
Snyper's Avatar
Around -10cc +/- some. My heads have 71cc's so I dont want to go crazy on the dish.
Old 12-13-2009, 10:17 PM
Rick_Vor's Avatar
I'm running the Wiseco KX444055 -11cc dish in a fresh Gm 6.0l block with a 4.005 hone. Hitting around 9.6:1 with Patriot LQ9 Stage ll's milled .030 and GM MLS gaskets. I got them from SDParts with rings for around $700.
Rick
Old 12-14-2009, 12:37 AM
Snyper's Avatar
thats what im looking for. Thank you.
Quick Reply: Can't find a good dished LS2 piston/rod combo(stock cubes)
