Have to pump the clutch pedal to get the car into gear
Can anyone help me diagnose this problem? The car is very difficult to get into gear and I have to pump the clutch pedal 3-5 times to get it into first and then sometimes to get it to change gears once moving.
Also, the clutch makes a bit of a ticking or clicking sound 3-4 quick times as I depress it.
It's an LS6 clutch with about 40k miles and no trips to the track and no time on drag radials on a bolt-on car. The clutch works great once in gear and doesn't slip at all.
Thanks a lot,
Chris
Thanks a lot,
Chris
Its certainly possible that this is a master or slave issue. But you could also have aerated the hydraulic fluid and may then need to bleed the hydraulics. I suggest using a mighty-vac and that you bleed from the valve off the slave and the reservoir too. Start by checking the level and qualtiy of the fluid in the reservoir. If it is dark, cloudy or discolored then you need to flush and refill the system. You can do this on your own or have a shop help you. If you find that this doesn't help then you can opt to replace the master and or slave. Details for these parts are listed below.
We offer an OE type master in two forms (regular and adjustable). The standard unit retails for $99. The adjustable unit is $175 (this version allows you to adjust the overall length of the rod that actuates the Master giving you the ability to modifiy the engagement point relative to pedal travel). Let me know if you want to order one and I will be happy to assist you.
Keep in mind that this could also be an issue relative to your slave cylinder. As you likely know the slave is mounted in the bell-housing and is more difficult to access, requiring that you drop the transmission. We offer the slave as well and it costs $109 with the bearing and $95 without the bearing.
