Have a bunch of engines and heads and cant decide on what to build
Old 12-21-2009, 08:52 AM
cjmatt's Avatar
Default Have a bunch of engines and heads and cant decide on what to build
My mustang is currently a ls1, th350 setup, but ive also got a 0 mile 99 5.3 iron block on an engine stand as well as a 70k pullout 6.0/4l80e from an 05 savana van. Ive got an extra set of 317s laying around as well. My ls1 has ported 853s also, but the compression ratio is bumped a tad cuz theyve been shaved. I was debating putting 317s on the 5.3 and running it with the 4l80e, then building the LQ4 up, then i also thought about 317'ing the ls1 and running that with the 4l80e. or else just drop the lq4, 4l80e setup in and see what itll take
Why cant this be easy. Plans are to keep it on E85, shooting for 600rwhp. Whatever motor it gets will be getting LS9 head gaskets, arp rod bolts, and headstuds, as well as a 2002+ LS6 Cam. I am debating whether to go with a victor jr. style intake, or else run my current LS6. Ive got a truck intake too, but havent heard much on how they run on boosted motors
Anyone have any input?
Old 12-21-2009, 11:48 PM
cjmatt's Avatar
anyone? i basically have3 setups to choose from.
5.3@8.5:1
5.7@9.1:1
6.0@9.5:1
choices choices
Old 12-22-2009, 08:08 AM
OUTLAWZ RACING's Avatar
Umm are you boosting it? Id go with the 6.0 and the 317 heads and throw 15 psi at it and be done with it.
Old 12-22-2009, 08:29 AM
cjmatt's Avatar
woops, shouldve probably stated that in the first post. yest, this will be a turbo car. doing a flipped truck manifold build in an 89 mustang notchback
Old 12-22-2009, 04:54 PM
For sho Id do the 6.0 it will add alittle weight but the power and tq these motors are making is dumb lol. You will be good at 800+ to the rear wheels on miner upgrades ie rods and pistons but stock I wouldent push it past 600.
Old 12-23-2009, 08:30 AM
cjmatt's Avatar
i think im going to swap the 317s onto the ls1 and do my turbo kit right now, then build the 6.0 as I get the $$$. That way i dont have any down time
Old 12-23-2009, 09:13 AM
Thats good also the lower compression will help with boost and save the motor a bit
Old 12-23-2009, 09:22 AM
99blancoSS's Avatar
What he said ^^
Quick Reply: Have a bunch of engines and heads and cant decide on what to build
