Finished installing monster level 2
Just finished the install and took it for a spin and it worked great! I was having a vibration and it is completely gone. The car is a lot more fun to drive now. Once I get it broke in, I will see if my high rpm shifting issues are gone.
1) I forgot to lock-tite the flywheel and pressure plate. Is that okay? (I torqued them to spec though FW=74 ft-lb PP=52 ft-lb)
2) It is chattering when I slip the clutch. Is this normal for a new clutch? (this was my first clutch install)
3) I'm a little confused on the break in period. Are you just supposed to be easy on it for 500 miles and drive around town a lot?
Thanks for the help!
P.S. I also installed a remote bleeder and it is amazing!
You might be ok without the locktite. I always do it for insurance. Yeah chatter is normal while breaking in most aftermarket clutches should go away with a stage 2. Break in is usually 500 miles of stop and go driving
i did my first clutch swap last winter and didnt no to use loctite. have put on over 22k miles since then of racing, road racing, street driving/ daily driver duties. and when i took it out after pulling the motor recently it was in great condition and none of the bolts were even close to loose.
just ordered a level 4 monster.had a spec stage 3+ that started slipping with about 6000 miles will never buy a spec clutch again!glad to hear that your monster clutch has you smiling.
installed mine with no locktite
4yrs and no problems.
for the break in the more around town you do the better.
they say 500miles, but that doesn't mean get on the highway with a full tank of gas and drive.
if you drive it in alot of traffic, you may be through the break-in faster.
Loctite is highly recommended, but as long as you follow the torque procedure you should be fine. Chatter is normal for the first 500 miles. PM me your email and I will forward you the break in instructions.
well i finished my install on my moster clutch and guys that do not have get one!I have had a Luke clutch Ls7 and spec3plus none of the clutches can come close to my level four.This clutch grabbs like a mf!and it surprises me at how soft it is.I am very impressed.
2000ss H/c fast 92 intake 92mm throttle body moser 9inch 150w/shot
thats good to hear monster clutches work well i plan on ordering mine (level 3 monster clutch ) for my 04 c5zo6 but im mostly stock other than a vararam,and cat bak borla stingers, diablo tuner , would the stage 3 work fine for me i do mostly daily driving and i get on it a lot but want something that will last and take a beating and will not wear to quick would the level 3 be a good choice or should i go with level 2? not sure but thinking level 3? i will be ordering it by monday(tomorro) thanks for the imput guys...............
the level 3 would be the correct choice for you simple because having a level 3 would be just like having a beef up Ls7 clutch and you will love that monster clutch thats a promise!
