help delete codes
help delete codes
Is there anybody that can delete my codes that I'm throwing.I'm throwing 02 codes and I believe missfiring codes. All the codes came on after my cam install so its the normal codes after a cam swap I'm assuming. I need to get the car inspected and my check engine light is on bc of them. My old tuner deleted the codes but they came back on and my new tuner is charging my 150 and I think that is a rip off.
So I finnaly found the codes here they are p0410, p0121, p0300, p0135,p0155, p0404. Some of them are repeats. Also every since the cam install I've been loosing oil and my low oil light keeps coming on but its not showing up in my driveway could any of the codes be causing that
You should try the local forum and see if anyone around you has a tuner that can make those changes. Pretty easy to do and you can pass inspection fine. But this costs money on the part of the tuner, to the tune of $100 for two credits...so the $150 that you are being charged is not exactly far fetched.
