help delete codes
Old Dec 29, 2009 | 05:53 PM
00 black ss's Avatar
Default help delete codes
Is there anybody that can delete my codes that I'm throwing.I'm throwing 02 codes and I believe missfiring codes. All the codes came on after my cam install so its the normal codes after a cam swap I'm assuming. I need to get the car inspected and my check engine light is on bc of them. My old tuner deleted the codes but they came back on and my new tuner is charging my 150 and I think that is a rip off.
Old Dec 30, 2009 | 06:26 PM
poconojoe's Avatar
What codes are they?
Old Jan 2, 2010 | 04:34 PM
i have to look for the actual numbers but i no they were misfiring and o2 codes
Old Jan 5, 2010 | 05:55 PM
So I finnaly found the codes here they are p0410, p0121, p0300, p0135,p0155, p0404. Some of them are repeats. Also every since the cam install I've been loosing oil and my low oil light keeps coming on but its not showing up in my driveway could any of the codes be causing that
Old Jan 5, 2010 | 07:40 PM
poconojoe's Avatar
p0121 TPS performance
p0135 O2 Sensor B1S1 heater
p0155 O2 Sensor B2S1 heater
p0300 Engine Misfire
p0404 EGR Pintle position error
p0410 Air System
Old Jan 5, 2010 | 08:47 PM
MUSTANGBRKR02's Avatar
Definetly won't pass if you removed Air/EGR without having them set to report no error in the tune.
Old Jan 5, 2010 | 09:03 PM
redtan's Avatar
You should try the local forum and see if anyone around you has a tuner that can make those changes. Pretty easy to do and you can pass inspection fine. But this costs money on the part of the tuner, to the tune of $100 for two credits...so the $150 that you are being charged is not exactly far fetched.
Old Jan 5, 2010 | 09:13 PM
I no but it should have been included in my regular tune and my old tuner won't do it. I really didn't want to spend 650 on a not that good tune. But if I have to I will spend that.
