Vortec Max....Good Motor....Good deal??
I have found a 2006 Vortec Max 6.0L engine and 2wd automatic (4l80E?) transmission, 49K miles, headers K&N cold air intake, supposedly tuned, and it comes with the harness, and computer and probably the gas pedal. Truck was slid sideways and totaled. They are asking $3500, but I have dealt with the guy outside of his job at the wrecking yard and he says he can get it to me for $3000. Is this a good deal, an average deal or just not a deal at all?
Originally he had told me he had a 07' 6.0L aluminum block out of an SS Silverado, variable valve timing, 6spd auto and thought it had 29K available. I was all in at this point! Turns out he is a little off on his facts when I received the pictures. He wasn't trying to bait and switch he just doesn't know any better. What do you all think, it will be destined for my '70 Chevelle and if it isn't the 6spd auto, I'd like to run my T56 any how.
IMO it depends on what you get with it. I just purchased an 2004 LQ9 (same motor as yours) 6.0 H.O. from a cadillac escalade. The purchase included a 4l60E tranny (from a different vehicle), the PCM, all engine bayt wiring harnesses, fuse box, the gas pedal (fly by wire), and lots of bits and pieces for 2200.00 tax included. (I purchased it from a Detroit salvage yard that of course made a profit on it).
Being that yours is two years newer it should be worth more, but it sounds like 3500 is way high. Are you getting everything with it?
I would physically look at the motor and trans before I buy anything form that guy! Hell could be a 4.8l!
Motor and trans out of the same vehicle still bolted together, computer, harness, pedal at least probably whatever else I need if I ask, they are pretty good about that. It was pulled as an as they call it "x-over" kit.
They also have a '00 Camaro Z28 LS1/T56 combo 118K miles and 160psi comp all around. They want $2950 for the motor and $1800 for the trans so $4750 for that setup. I was quoted on this combo before I met this guy and I am sure he can get me a better deal, he is one of their wholesale guys, but it sounds steep$$$, especially with 118K miles.
I was also quoted $1000 for a '99 5.3L with computer and harness out of a 99 Silverado, with 70K miles, but I don't think I am going to go that route.
I have pictures, if I can figure out how to get them from my E-mail to here I will post them. It says Vortec Max on the plastic cover and 2006 GMC 6.0L VIN-N X-over on the tag so I am sure it isn't a 4.8L. Must be a 4l60E than, I don't think it has been changed.
Vortec Max and SS came with 4L65E/4L70E depending on yr IIRC. IMHO, that is kinda high. i paid 2k for my LQ4/4L60E combo w/ 30k miles on it. I'm sure you could find a better dealfor one. If you won't be using the headers, intake, etc, you could make some of that back by selling that stuff.
My experience has been the prices for the same mileage on Gen III / IV engines go like this:
Description ------------------- Price
Aluminum car LS* ------------- Insane / first born, bag of gold coins, etc. Not worth the 65 LB weight savings in most cases.
6.0 truck engine -------------- A touch high (IMO), but obtainable. Only worth it if you are extensively modding the engine or racing (swapping to bigger heads, stroking, etc.)
5.3 truck engine -------------- Best deal / power for the $$$. Also happens to be BY FAR the most common size.
4.8 truck engine -------------- Nearly free (comparatively), good for a driver, not for modifications.
The prices also vary yard to yard and region to region. This has been compiled by my own experience, searching and the unsolicited quotes stated by people on this and other forums.
In my HUMBLE opinion for a DRIVER you don't plan on internally modding a 5.3 is your best bet. You aren't really going to notice the extra .7 liters of displacement or 40 - 50 HP from the high output 6.0. Please don't confuse this with saying you shouldn't buy a 6.0, I'm just showing you the door to other less expensive options.
All 4L60E's of the vintage you mention will say 4L60E and M30 on the case.
i personally wouldnt pay that much for any motor or trans setup,, unless built up or like 08' or newer.. thats way to high in my oponion,,. i found a 6.0/4l80e for $1500 with everything.. and i found another one with 4x4 unit 4l80 for $1000.. id wait on a good deal to come around.. . for 3500 u can get an ls3, just motor,, i have 4l80e for sale $480 bucks..
That code will tell you what type of vehicle the transmission came in, what year and what transmission it is - IF you can decode it.
I agree with chevellepowered on the price. My hang up seems to be getting 2WD transmissions cheap, but I can get engines and 4X4 transmissions all day.
I also agree with the comments about the H.O. 6.0. It's rare in comparison, and because of such it's more expensive. You could probably pick up a ~315HP 5.3L on the cheap.
One of the other things that I personally considered in my purchase for example is the type of duty that I anticipated my motor experinced. A 6.0L in a pickup with a towing package was probably worked a bit harder than an escalade status-mobile. Also, with a simple head/cam/intake swap, my motor would be in the same (or better) ballpark as an LS2 GTO/vette motor at 400+ factory HP which is the direction that I would like to head.
So all in all it really does depend on what you want to do with your setup.
They also have a '00 Camaro Z28 LS1/T56 combo 118K miles and 160psi comp all around. They want""""""" $2950""""""" for the motor and $1800 for the trans so $4750 for that setup. especially with 118K miles.
holy f#%,, damn,,, i will sell you my 08' ly6 12 miles on motor, and 4l80e with the trans and 3200 stall, """for $4750"" ,and i'll let you hang out with my girlfriend too,, hell i'll install it for you,,,haha,,
thats just plan rip off..
just wait for good deal,,id stay away from those people..
I am pretty sure the motor was worked. It has headers, an intake, a tune, and slid into something. These guys are pretty much the only place local if I don't want to pay shipping and inspect the motor first. I plan on some sort of forced induction in the future. The car will be a summer driver and flogged regularly. What is the trans worth if I sell it separately? Maybe they would go $2500 if I twist their arm. Is the Vortec Max worth any more than a standard LQ9 or LQ4?
I just talked with the guy and it turns out he can get me a 69K mile LS1/T56 conversion package for $4,000 out of a 2000 Z28. If I put some money down he can hold it for me for a couple months. That is the setup I originally wanted. $4K sounds reasonable for the overpriced aluminum block LS1 6spd combos to me. He can also get me a LQ4 or LQ9 engine with 50-60K,harness, and computer for $1700. I am leaning towards the LS1.
