will a 93 z28 fuel pump work in a 97 camaro 3.8?
wasnt sure where to post this
but heres the idea
i have a 93 z28 that i dont drive.
i have a 97 camaro 3.8 that i'm trying to sell. the fuel pump went bad. so i took the fuel pump out of the 93 z28.
was this safe?
car runs fine.
if thats fine. then my next question is... are the fuel pumps off ebay ok to use in the z28?
or would i be better off putting the original z29 pump back in the z28. then buy a ebay fuel pump for the 97 camaro 3.8 that i'm trying to sell?
but heres the idea
was this safe?
car runs fine.
I am almost sure that you won't have a problem with using the z28's fuel pump in the 3.8, since it plugged in nicely and the z28 pump maybe works harder than a 3.8.
So it will be fine.
Ebay car things are a hit or miss. Car may or may not run, or just run like crap because not enough fuel being pumped.
So it will be fine.
is this a good one?
http://cgi.ebay.com/ebaymotors/255-L...Q5fAccessories
255 LPH FUEL PUMP Chevrolet Camaro 91 92 93 94 95 96 d
so what should i do.. put the z28 pump back. and get a cheap 20 one off ebay for the 3.8 that i'm selling?
whats the differences between the 3.8 and 5.7 fuel pumps? putting a v6 pump in a z28 wouldnt be so good would it?
heres what the ebay one says
Performance:
Pressure: 30-115PSI Operation Pressure;
Flow: 210-255 Liter Per Hour, at 3.0Bar/13.5V;
Voltage: 12V Min.
would that work better or worse than the stock z28 pump?
Performance:
Voltage: 12V Min.
well that fuel pump already went bad. 3rd one now i think.
guess i'll try a brand new one.
first time i think i had a hose backwards. but the recent one i didnt take apart, i hooked it up right now.
is there a fuel pump relay or any ideas on what the problem is?
http://cgi.ebay.com/ebaymotors/FUEL-...Q5fAccessories
heres one cheap for 15. but it says for 99, 01, 02. should fit a 97 too???
the u-pull-it junkyards here take the fuel pumps out.
the regular junkyards will probably want 100+
do the 99-02's have different engines or something? or is it suppose to say 98-02? my 98 firebird has the same engine as my 97 camaro. so it should work?
I'm not sure on the year they changed but they use to have 3.4 liters in the Camaro's then went to the 3.8..... the 97 and 98 would both have the 3800 Series engine so it would be the same.... They changed the v8's in 98 as everyone knows...I think it was like 95 when they changed from 3.4 to 3.8....could be wrong though but I'm pretty sure I'm right...
the ebay one comes with a warranty.
sound like a rip off? thats cheap
Price: US $15.45 Buy It NowBuy It NowBuy It Now
Now watching in My eBay (94 items)
Coverage: Pay with and your full purchase price is covered | See terms
Shipping: $8.55US Postal Service Priority MailSee more services See discounts | See all details
NEW FUEL PUMP MODULE REPAIR KIT
THIS KIT REPAIRS THE FOLLOWING MODULE
AC DELCO # MU167
GM # 25316320
BROADCAST CODE "FRN"
YOU ARE BIDDING ON A ELECTRIC FUEL PUMP WITH COMPLETE INSTALLATION KIT
EXCLUSIVE OF GLOBAL AUTOMOTIVE OF MIAMI, INC.
COMPLETE INSTALLATION INSTRUCTIONS INCLUDED
THIS KIT REPLACES THE FUEL PUMP LOCATED INSIDE THE MODULE ASSEMBLY
EASY "DROP IN" INSTALLATION. DO IT YOURSELF & SAVE!
LIFETIME WARRANTY!!
KIT INCLUDES THE FOLLOWING:
1 BRAND NEW HIGH PRESSURE ELECTRIC FUEL PUMP
1 BRAND NEW GREEN INTERNAL STRAINER / FILTER
1 BRAND NEW YELLOW EXTERNAL STRAINER / FILTER
1 BLACK INLINE HOSE
1 CLEAR FUEL HOSE
KIT WILL REPAIR THE FOLLOWING VEHICLES:
Year Make Model Engine
2002 CHEVROLET CAMARO V6 3.8L 231cid GAS FI N Engine VIN = K
2002 PONTIAC FIREBIRD V6 3.8L 231cid GAS FI N Engine VIN = K
2001 CHEVROLET CAMARO V6 3.8L 231cid GAS FI N Engine VIN = K
2001 PONTIAC FIREBIRD V6 3.8L 231cid GAS FI N Engine VIN = K
2000 CHEVROLET CAMARO V6 3.8L 231cid GAS FI N Engine VIN = K
2000 PONTIAC FIREBIRD V6 3.8L 231cid GAS FI N Engine VIN = K
1999 CHEVROLET CAMARO V6 3.8L 231cid GAS FI N Engine VIN = K
1999 PONTIAC FIREBIRD V6 3.8L 231cid GAS FI N Engine VIN = K
WE CARRY & SUPPLY THE FUEL PUMP REPAIR KITS FOR EVERY
AC DELCO # MU167
GM # 25316320
LIFETIME WARRANTY!!
1 BLACK INLINE HOSE
1 CLEAR FUEL HOSE
about to order that pump for my 97 3.8.
would it work on a 93 z28 also? i know it'll fit. but is the specs the same? would it hurt the z28? my z28 also needs a pump
