Car shakes a bit too much
Well im sure this is not the right place to post this, but i trust my fellow texan members
Well i installed Some long tubes and a y pipe with a cut out right in front of the cat back.
And well... i tried to extend the o2 sensors, (the ones mounted on the headers) and failed, and of corse my y pipe is off road so no o2's there
But i do get my SES light on and it tells me all o2 sensors dont work, (lucky me)
And well on idle the car shakes a little... more than it did before, and sometimes it bogs... only on idle tho!
The car idles a little over 500 rpm... is this normal?
Does my car need a tune?
can a tune take out the o2 sensor stuff? and never let it come on again?
or do i have to buy new o2 sensors and buy extensions and by 2 o2 simulators for the 2 rear o2 sensors?
If you need any more info please ask ill reply asap.
What o2 sensor is throwing a code? here is a example bank 1 sensor 1 or bank 1 sensor 2 if it is sensor 2 on both sides then you can have them tuned out. If it is bank 1 sensor 1 or bank two sensor 1 you have problems with your primary o2's witch you will need to fix
i had the same problem and went thorw about 5 sets of o2's, for different reasons, but the problem you stated can be fixed by getting the rear o2's tunned out and get some extensions for the front or get some corvett o2's and replace them if that doesnt fix it then you may have some other probelms somewhere, also make sure you have the little blue seal thing on the connectors, getting water in there will cause it to bog and run funny atleast it did mine anyways
both up front
both out back
meaning i didnt extend the o2's correctly.
( i know stupid me)
i got the smart idea of extenting the o2 sensors my self.
lol
well start with extending them correctly and see if you have the prob. the rear o2s dont matter the front ones are the ones that control the A/F ratio. you need to get the front ones working( get the known problems fixed then work on the rest)
If its the front sensors on the headers, and they are not plugged in, your car will run in closed loop operation only and run like ****, that mode is only to be used till the engine gets warm. Plus the sensors on the headers are not o2 they are air/fuel sensors that tell the computer how to adjust the trim to maintain 14.1 air to fuel mix. A tune will not fix this.
Ummmmm..... A o2 sensor in combination with the maf, Map, and Iat sensors tells the computet what afr to run. Yor front 02s are for warm up, the second set are for fuel eco. Just got to be sure they are plugged in right. O2 extensions suck ***** the bosch 13111 have a 4 foot pig tail more than enough for any long tube header. and to the op, All 02 sensors except widband o2 are the same for 98-2002 corvette and Fbodies, gtos are differant and the c6 models are aswell.
Your front o2's send a signal to your pcm in mv anything below 50mv is lean and above 900mv is rich and from there your pcm uses stft's and ltft's to do the correction to reach 14.8 afr and when you go into power enrichment mode aka WOT throttle, all st and lt trims go to zero. Or at least that's what i think i have learned so far
i got a set of the o2's u recomended and there nice and im going to put them on tomorow,
now i just need to tune out the rear o2's?
I know this post is old but i started to drive my car around again
and it stil shakes.
has turned off on me at-least 4 times.
i changed the fuel pump it was bad 70,000 miles and it was still the stock unit i believe.
I got the corvette o2's on there but i still not running the rear o2's
will the rear o2's really make my car shake on idle?
Remember... it only does this sometimes,
When ever it feels like it.
Fuel pump?
and it stil shakes.
Fuel pump?
running no rear o2's with out a tune should be no prob. i have not running rear o2's and dont have a tune yet and my car runs just fine, made 334 to the wheels... did you check clearence for your headers? are they hitting your K-member or maybe your floor board or something along those lines? if it is, that can cause some vibration in the car... a tune will make the car runn better and get more power out of it, but is still NOT NECCESARY, but is a good investment!
