48" driveshaft????
Old 01-03-2010, 01:43 PM
03 BUSA's Avatar
Default 48" driveshaft????
Been doing some searching on what guys are running for driveshaft lengths and the numbers did not seem right to what I have so I thought I would measure my setup again and get some thoughts. Center to center on the driveshaft is 41 3/4" and from the front of the slip yoke to the rear center of u-joint is 48" seems a little on the long side????
Old 01-04-2010, 01:01 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
correct with your application. the f-body cars dont require much slip travel at the yoke due to link and torque arm type suspension.
Old 01-04-2010, 08:03 PM
03 BUSA's Avatar
Thanks Eric. Just wanting to double check Strange's stuff while it was out. I have noticed it is hit or miss with axles and d shafts.
Quick Reply: 48" driveshaft????
