should i use predator on a tunned ecm
Old 01-05-2010, 07:48 PM
randall 32's Avatar
Default should i use predator on a tunned ecm
I bought a used predator u7193 planning on using too tweak shift points and tune. My ecm has already had a mail order tune with vats, rear o2 removed yata yata yata. My question is can i modify things without messing things up that have already been done.
Old 01-05-2010, 08:45 PM
MUSTANGBRKR02's Avatar
Don't believe you can. I know my old predator could only use the stock tune.
Old 01-05-2010, 08:55 PM
randall 32's Avatar
i was afraid of that, i read somewhere that if i already had a tune that it would mess it up. im trying too confirm. thanks
Old 01-05-2010, 09:00 PM
redtan's Avatar
What you can do is read the current tune and save it to your predator. Then from there you can adjust whatever parameters the tuner lets you change. I don't think stuff like shift points can be changed.
What you can do is after you download that tune to your handheld, upload it to your computer and email it to a tuner that can make those adjustments for you using the diablosport software. Then you load it back to the handheld and back on your car.
Old 01-05-2010, 09:26 PM
randall 32's Avatar
I need too get the wire too connect too my laptop. Ill try calling diablo sports tomorrow too see what they can do. Thanks
Old 01-06-2010, 10:15 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
The GM Predators will read anything off the PCM (unless it is locked, obviously).
The Predator will allow you to modify the 'stock' tune once it saves that file in its memory.
It will let you modify shift points, rev and speed limits, and even WOT fueling and spark, and more.
Old 01-06-2010, 04:46 PM
Is this so even with the older units?
Old 01-06-2010, 10:19 PM
randall 32's Avatar
So, since my tune isnt stock i cant use the predator?
Old 01-06-2010, 10:25 PM
no1izspeshl's Avatar
The "stock" tune would be the current tune. If I read what Mike is saying correctly.
Old 01-07-2010, 09:18 AM
LS1Tech Sponsor
06MonteSS's Avatar
correct... whatever tune is currently on your pcm, the predator will read it and save it as the stock "original backup"... whether it's really a stock GM tune or not... whatever is on there now, will be saved as the stock/original backup tune...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 01-07-2010, 06:44 PM
randall 32's Avatar
has anyone tried this? i called diablo and they said i had too have the stock tune reinstalled and go from there. the stock tune would reinstall vats, rear o2s and things i don't need for a car with a engine swap. i didn't want too redo the whole tune just tweak what i have.
Old 01-07-2010, 08:24 PM
macca_779's Avatar
I think your pretty much screwed with the Diablo mate. Sell it and buy EFI LIVE or HPTuners. Both those are a thousand times more capable.
Old 01-07-2010, 08:46 PM
randall 32's Avatar
i think your right, thanks.
Old 01-08-2010, 08:37 AM
LS1Tech Sponsor
what a ridiculous statement.
The Predator will do EVERYTHING he has asked.
It seems I somehow confused him with nomenclature, but yes, what you asked will work.
Period.
GM Predators will read ANYTHING off of a GM PCM unless the tune is locked.
It will allow you to modify that tune to your liking.
When you restore the 'stock tune' back to the car, it is not some generic stock tune with VATS and whatnot, it is what it READ from your car initially.
I have flashed dozens of cars with a Predator that were already tuned with HPt or EFIlive, no biggie.
Old 01-08-2010, 08:38 AM
LS1Tech Sponsor
I'll never understand this...
I took the time to explain all of this to you, even after you openly stated you bought it used, and you think you are screwed?
I'm lost now.
Old 01-08-2010, 08:39 AM
LS1Tech Sponsor
Yes sir.
Old 01-08-2010, 04:47 PM
Thanks
Old 01-08-2010, 05:43 PM
adkunlimited's Avatar
i have used diablo before and the unit did everything they said it would do. you cant ask for anything more.
Old 01-08-2010, 08:25 PM
Frost's Avatar
I'm lost now.
Maybe it was this:
Old 01-08-2010, 10:21 PM
randall 32's Avatar
Mike, I buy no means meant too dis DIABLOSPORTS, but i did call and was told that i had too start with the stock tune and your first post had 'stock' in parentheses. So i wasn't sure if in fact i couldn't do what i wanted or if this was a disclaimer, so i was asking if anyone had modified a previously tuned ecm. Thanks for your help and your time.
