Please Help NEED LUG NUTS
I just bought some Weld XP Draglites and will need lug nuts. I got a hold of Summit and they said when Weld went out of business so did the lug nuts?? Do you guys know where I could get some from? Or does anyone have some they would want to sell. They are going on my 2002 Z-28
still looking for these? i have a brand new set of dorman with gorilla lugs and locking lugs, with keys. never used, brand new. $40.00
email me at rbbell.ams@gmail.com
Weld XP Lugs
Autozone is where I bought mine. Tell them you need the shank style lugs. Get the longer studs while your at it. Put them on yourself by hand before tourqing them down. Don't rely on a tire shop to do it. Trust me, I just went through this bs and they stripped at least two studs per wheel. Longer studs are a must for saftey issues. When you do the backs, just take out the abs sensor and the studs will slide out of that hole.
I do not think these can be purchased from any local shops. Even the lug nut manufacturers do not make one. As far as longer studs, I do not know why you would need these. The lugs reach down to within 1/4 inch of the mounting surface giving you 90% or more lug engagement. I know of one or two shops that may have what you need. PM me with the information of the thickness of the center section so I know which lug shank to look for.
Hope I can help.
