Narrowed or stock length?
Old 01-08-2010, 09:23 AM
second_2_none's Avatar
Question Narrowed or stock length?
I am about to buy a midwest chassis fab 9 but I dont know if I should have it narrowed or not. Other than saving a little weight, what does it benefit to have it narrowed. Also if I do will it be harder for me to find wheels for it since I would have to have a different backspace? The car is not a daily driver, but is deff a weekend warior/strip car. It sees the road 2-4 times a week depending on weather.
Old 01-08-2010, 11:26 AM
Anyone? I could really use some opinions and advise.
Old 01-08-2010, 11:36 AM
transamsam98's Avatar
it really all depends on how much you narrow it. it will open up the possibilities for drag wheels if narrowed and it will wiegh about 5-7lbs less other than that theres really no benifit unless you tub it as well then you can tuck a bigger tire.
Old 01-08-2010, 11:40 AM
Banned Village Idiot
LS1BLKSS's Avatar
what size wheels were you planning on getting?
Old 01-08-2010, 11:41 AM
Hey thanks a lot man!
Old 01-08-2010, 11:48 AM
I am planning on getting some big and littles, 15x10 in the rear for the strip. But I also am getting some wheels for the street, probably 17x9 or 10.
Old 01-09-2010, 04:25 PM
ABQ99TA's Avatar
I'm in the same boat as you and have been looking into this issue. I think if you are planning on running street wheels when your not at the track stock length would be best. If you have it narrowed your street wheels will be set in deeper and look funny. Unless you plan on buying new wheels for the street and can change the backspacing to match your set up.
Old 01-11-2010, 07:27 AM
teke184's Avatar
BS street lights...you can pick your backspacing.
narrowed will give you the option for a deep lip...which is SEXY
