tunnercats help
Old 01-08-2010, 04:51 PM
keeven1320's Avatar
Default tunnercats help
i have a 95 z28 an the tunnercats software, i am having trouble getting the software to read the pcm. it starts to read gets about half way and stops says it "had a cable failure" i have read the installation instructions over an over, pretty sure everything is setup properly. anyone have any suggestions or tips? thanks
Old 01-08-2010, 05:58 PM
flame's Avatar
Did it ever work? Is the cable new? Do you have any logging software you could use to verify the cable is good?
Old 01-08-2010, 06:17 PM
keeven1320's Avatar
the cable is brand new bought it from tunnercats i have not got it to work yet, i have pcm communicator an cant get it to work also. with tunnercats i can get it to read the vin so i do know its somewhat reading. also i dont think this would matter but i do have a pcm out of 94 that has a tune on it already in the car.
Old 01-08-2010, 06:18 PM
9-Second Club
Ed Wright's Avatar
Could be a dirty/poor connection. If you have a usb cable, try another port in your laptop, or another usb cable. I have both usb & 9 pin serial cables, and have had cable and connection failures with both kinds. Likely you have a problem with a cable or connection problem between your pc and the module in the cable.
Old 01-09-2010, 12:05 PM
keeven1320's Avatar
i have a usb cable, an 6 comm ports on my lab top. i have tried all 6, ill mess with it some more an see if i can come up with something. thanks for all input
Old 01-09-2010, 01:17 PM
JonCR96Z's Avatar
Where did you get the cable? Can you verify that you have power on your OBD port?
Old 01-10-2010, 03:53 PM
keeven1320's Avatar
i got the cable from tunnercat, yes OBD port has 12v
Old 01-10-2010, 04:35 PM
poconojoe's Avatar
Try using a powered hub, I had trouble with my external drive, because my notebook didn't supply enough power from the USB to power it, using a powered hub fixed the issue
Old 01-10-2010, 10:26 PM
keeven1320's Avatar
thanks ill give it a try
Old 01-11-2010, 03:19 PM
wait4me's Avatar
What is the voltage on the car when it is happening? A small car charger might help.
Also, maybe changing the port settings in your control panel to allow faster transfers might do it? I think most of the time, the ports are set to 8600 or something really slow. move it up to 112k or 56k..
Old 01-13-2010, 12:35 AM
roughneck427's Avatar
go back and read Tunercats site if you bought your kit in the past 4 to 6 weeks you might have to update the software theer was a problem with it with the LT1 package stuff
Old 02-01-2010, 12:05 AM
keeven1320's Avatar
i got everything working now, i ended changing out the pcm with a spare i had and its working great now. thanks for all the help
Old 02-01-2010, 08:40 PM
poconojoe's Avatar
You might want to register on the Monodax forum, for TC support, you'll find a lot of the guys from here that use it, over there
Old 02-01-2010, 10:23 PM
keeven1320's Avatar
alright cool ill check it out
