My 02s keep fouling out... any ideas?
Old 01-11-2010, 05:53 PM
Donohue96M6Z28's Avatar
Default My 02s keep fouling out... any ideas?
Again, has some of you know. I've been having bad mpg for the past few months. I had someone on AFBForums work on my car/tweak my tune for a couple weeks, but we can't seem to figure out what the issue is. My 02 sensors keep fouling out, also he swapped out my MAF sensor bc it had a bad port job and placed an slp 85mm MAF. Its getting bad mpg(7mpg), and does not feel/sound strong at all. The MAF tables have not been changed from stock...
Old 01-11-2010, 06:04 PM
winger4800's Avatar
whate are you tuning/tweeking it with? How do you know they are fouling out?? (ses light?, visual?) what kind of gas? plugs? have you checked for vacuum leaks?
Getting too much gas for sure it sounds like.
Old 01-11-2010, 06:13 PM
HP tuners, he was just messing with the VE tables/fuel injectors. I believe that they are fouling, bc when I get them changed out. The car runs good for a short time. Also, the long term fuel trim on the drivers side 02 was high. We put in a new 02 sensor on that side, and put that same 02 sensor(from the Drivers side) on the passenger side. We reset the fuel trim, but it quickly got worse. So it followed the 02 sensor... I just got another 02 sensor to put in on that side, but haven't put it in yet. I put in superunleaded (93). And I changed the plugs to t55s when the problem started a few months back.
He noticed an exhaust leak, and replaced the header gaskets.
Old 01-11-2010, 06:50 PM
98silvertacrbn's Avatar
What was your stft & ltft at and what was the voltage of your o2's at idle
Old 01-13-2010, 02:24 PM
Heres a couple logs I did earlier today...
File Type: hpl
File Type: hpl
Old 01-13-2010, 03:20 PM
pm sent
Old 01-13-2010, 04:41 PM
Heres 2 logs with the fuel trim shut off, they're short bc it kept disconnecting
File Type: hpl
File Type: hpl
Old 01-13-2010, 05:23 PM
In both those logs when you car went into closed loop your fuel trims were still on. Are you turning them off with the editor or just clearing them?
Old 01-13-2010, 09:12 PM
I was resetting the fuel trim, and then shutting it off, I thought...
Old 01-13-2010, 09:20 PM
Sarge_13's Avatar
Damn Patrick you aren't having any luck with that car at all huh bro.
Old 01-13-2010, 09:55 PM
I would start with changing the o2 on the passenger side it looks to have the most problems.
Old 01-13-2010, 10:07 PM
In the editor or scanner? I always turn my fuel trims off in the editor also does it run better on cold starts or when it's warmed up?
Old 01-13-2010, 11:20 PM
Ya man, its been a big headache for the past 4-5 months.
Its 2 days old (~10 miles or so).
Old 01-13-2010, 11:21 PM
In the scanner... and I haven't noticed any difference between the cold starts/warm up.
Old 01-13-2010, 11:35 PM
INVISIBLEZ's Avatar
The POS is doomed, run it in the wall.
Old 01-14-2010, 11:09 PM
Sam88Gta1's Avatar
You need some serious work on the tune.
Old 01-14-2010, 11:39 PM
But the problem just started out of nowhere, it's had this tune for 2+ yrs. Do you think a quality tune will fix it?
Old 01-15-2010, 12:06 AM
bobbyd's Avatar
get Turtle to tune it
Old 01-15-2010, 12:08 AM
Yeah I'll probably have him do it, just hoping this isn't being caused by some other problem. Ie, bad injectors etc etc
Old 01-15-2010, 12:19 AM
bobbyd's Avatar
are you getting any ses lights? missfires etc?
