It is ok for me to run NOS with the setup I have?
Ok this is what I have...
02 ls1 6 speed..
5.3 heads ported by TEA to 1.5
comp cam 224 224 581 581 112
FLP's and a K@N FIPK intake....
right now the car makes about 410hp and 400tq
The best I can run out of it is 12.5 at 118 with a 1.9 60" on Nitto's
I want to spray a 100 shot on the car.. Not schure what kit to go with or.. If its even safe to put NOS on the car.. Condsidering I no with
these heads my compression is going to be like 11.1 prob.. Not schure exactly what it is....
Is it ok to spray with this setup?
If so what kit? and how much schould I spray??
Thank You..
Frank
02 ls1 6 speed..
Thank You..
Frank
TR-6 plugs.
Timing advance set to about 23 degrees.
O2s at 910-.950mv.
75 shot.
You'll be safe.
Upgrade the fuel pump (and injectors too for a dry shot) and drop the timing back a little more to spray more. Unleaded race gas is also a really good idea.
O2s at 910-.950mv.
75 shot.
You'll be safe.
What type of kit.. Is going to work safe.. And is a 75 shot the most i can spray since i have heads and cam.. And stock bottom end.. And high compression..
whats the safest and best kit.. and can I spray a 100 shot.?
I dont think that iam having that bad of traction prob.. At the track.. yes.. but not on the street..
what kit is the best i can go with for being safe and performance..
with my high compression heads and cam..
can i spray a 100 shot..
what about a direct port system.. Is that not a good kit to go with or yes?
Caqn Some One Please Help.. Me I Have Decided Not Go Try To Go With A Bigger Motor The 383 Kits Are To Much $$$$
I Would Like To Spray But Dont No What I Can Spray With What I Have.
To Be Safe.. What Kit Schould I Go With And How Much Schould I Spray.?
there is a guy got the same set as you , he dyno 420rwhp and he was running 11.5 (na)
he was spraying 150 shot wet kit (mods svo 30Inj and bigger intank fuel pump )
Originally Posted by SuperSlowSSLS1
What kit was did he have? All I want to do is spray like a 100 shot i dont want to risk blowing up my motor..
i don't have his time with 150 shot(nx shark nozzle )
hi frank, ask the colonal with kit is best, and look at his files, Ive still got the new nos kit thanks jerry
