Stock exhaust on '01 Camaro SS?
Gentlemen - does this exhaust below appear to be stock on a 2001 Camaro SS? Does anyone recognize it if it is not?
Thanks!
Thanks!
A muffer shop can install whatever you want but there's really no point in just adding a muffler. I'd start with a catback(there's about 32 million threads on all the catbacks on this forum, just search) and go from there.
stock, the car will sound like nothings there... when i test drove my T/A the first time, i was highly dissapointed with its non-existent growl, from the time i started it up, to being on the freeway, it was so quiet. I have the Loudmouth 1, and it sounds so much better. i can post up a video in a little bit to show you. It should help you decide, since everything else is still stock.
Banned Village Idiot LS1BLKSS
I don't see a pic... but if it's a SS it could have the SLP dual/dual on it. They are very quiet on a stock car, but very desirable by many with a heads/cam car. It is no longer in production so if this is what it is I would hang on to it if you take it off. You might want it back on there later if you do some motor mods.
I'm sure its just the basic stock set up ,^^^If it was a daul daul from slp the tips would be 2 on each side like loud mouth have . Get a cut out leave alot of factory things on your car it will holds its value.
