How stiff should a 12 bolt be?
Old 01-16-2010, 02:50 PM
IH8FORD's Avatar
Default How stiff should a 12 bolt be?
I have a strange 12 bolt and I noticed with it up on jack stands that you can't spin the tires freely. I pulled the brakes off and unhooked the drive shaft. The rear end is really stiff. I would think with everything off of it the things would spin freely. It takes both hands to turn it a little at a time. Does anyone know what kind of pre-load I should have on this thing. Or how hard is yours to spin.
Old 01-16-2010, 03:34 PM
DaddySS's Avatar
As long as you have those off (and the wheels too) , the total preload on the 10 bolt is like 35 in/lbs for a new build (that's without the axles). I would pull the axles and check that it is around there or less to be sure.
Old 01-16-2010, 06:44 PM
IH8FORD's Avatar
So you do check the preload with the diff. in and just remove the axles?
