AFR 205's installed
AFR 205's installed
Great set of heads! Straight forward install. Also installed new lifters since I had the heads off. Feels as fast as my old '06 GTO that ran 12.65 on street tires....
Need a clutch now.....
Sweet. Do you have power and torque numbers for your set up? Any vids of how the cam sounds?
My lift is now tied up with my avalanche. Broke the output shaft on a 1-2 shift at 8psi and the motor over revved and took out one of the DOD lifters. Gotta pull the heads off that.... hope it didn't take out the LS2 cam I have in it
Please don't hold your breath... I work a lot of hours and getting it to a dyno is low on my to do list. I just like installing stuff to make it go faster.
I use HP tuners and a WB. Have it dialed in pretty good now.
Definitely need to upgrade the clutch. I'm thinking Monster stage 3.
The level 3 would be just right. Gives you plenty of room for future mods. Car sounds great!
The Monster packages come with an 18lb or 28lb flywheel...your choice.
[QUOTE=whisler151;12802555]The level 3 would be just right. Gives you plenty of room for future mods. Car sounds great!
Thanks! Monster lvl 3 ordered yesterday. Should be able to get installed in a couple weeks...
