Anyone making 550HP on a stock bottom 346ci???
Old 01-18-2010, 09:31 AM
teddyca's Avatar
Default Anyone making 550HP on a stock bottom 346ci???
Car is an 01 Z with heads, cam, etc.... Makes 450hp to the rear and was just tuned about 2 months ago. Ordered up my new plate kit and thinking of a nice 100hp shot but dont want to scatter the bottom end. Car might see spray 4-5 times a year. This is not for the street but instead the track and dyno. I obviously will have it tuned for the bottom I just want to watch my limits. I have read in the past that either 500hp or 600hp is about the limit but dont remember which rule of thumb it was. HAHA
Old 01-18-2010, 11:39 AM
Chris@NitroDaves
Guest
Posts: n/a
You should be fine spraying that size shot. One thing that you will need to take into consideration though is that if you haven't upgraded the fuel pump you will need to do so in order to properly run the kit.
Old 01-18-2010, 11:45 AM
teddyca's Avatar
I thought the pumps on the Z06's are pretty stout??? I do have 48lb injectors if that matters?
Old 01-18-2010, 11:46 AM
ttranssam's Avatar
i have to be close to the 550 mark...im bumping up to a 175 soon
Old 01-18-2010, 11:52 AM
teddyca's Avatar
That a boy. I think the Lingenfelter heads I have and cam should be fine it was the crank, rods, etc... that concerned me. Like I said it will not always be spraying. This is a full show car and 75% the reason another bottle is in the car.
Old 01-18-2010, 11:58 AM
Chris@NitroDaves
Guest
Posts: n/a
They do have a good pump but it would be better if you can at least put a Hotwire kit on there or a Kenne Belle Boost-A-Pump so that away you know you are covered for fueling.
Old 01-18-2010, 12:05 PM
66351coupe's Avatar
I think theres quite a few people making that on stock bottom ends a good set of rod bolts are nice security though once you start spraying.
Old 01-18-2010, 12:06 PM
ttranssam's Avatar
yup thats the only thing i need to do is get bigger injectors, and i wanna do the twin in tank pumps. i have the hotwire kit now with the pump in but i just wanna b safe...what size injectors for a 430 na and roughly 575 n20???
Old 01-18-2010, 12:40 PM
teddyca's Avatar
I have 48's and they should be fine. I will look at the duty cycles when I am tuning and see if a KB is needed. Thanks guys
Old 01-18-2010, 01:06 PM
camscam02's Avatar
check out my thread above teddy, went 139 on the bottom end. It should make over 550. haha.
Old 01-18-2010, 01:09 PM
teddyca's Avatar
Nice. If I can run your times off the bottle when I am on the bottle I will be one happy camper. HAHA
Old 01-18-2010, 01:21 PM
camscam02's Avatar
yea that would be a pretty good time. I would def. be happy with that if i were you.
Old 01-18-2010, 01:51 PM
66351coupe's Avatar
Your injectors will stay the same with nitrous if you use a wet kit (it supplies it's own fuel) but id upgrade pump like you mentioned with hotwire kit.
Old 01-18-2010, 06:48 PM
BottleFedZ346's Avatar
500rwhp on a 100 hit im now on a 175 kit 115k and stock internals you should be fine......
Old 01-18-2010, 07:29 PM
vette0009's Avatar
Changing out a fuel pump is alot of work on 01Z isn't it ?
I have a 03Z and my fuel pumps are located inside the tanks
Or are you talking about putting the Kenne Belle Boost-A-Pump In-line ?
Bon
Old 01-18-2010, 08:23 PM
blue99fbody's Avatar
i was making 550 on my stock bottom for a long time and beating the hell out of it
Old 01-18-2010, 10:10 PM
jdaniel's Avatar
10.50 @ 137 on a 150 shot with a crappy 1.60 short time. I make 460 and 400 on motor then the 150 shot so im over 600 to the wheels and havent had a problem yet (knock on wood).
Old 01-18-2010, 11:08 PM
BayAreaSS's Avatar
You'll be fine. Just get a fuel pump and a good tune
Old 01-18-2010, 11:24 PM
mchdg86's Avatar
Bon
The fuel pumps on 97-02 and early 03's are stupidly easy to change. All he will hafe to do is remove the left rear tire and the heat sheild covering the fuel tank and he will have access to the pump. On late 03's and 04's they moved the pump to the top of the tank reqiuring you to remove the tank from the car to get to the fuel pump.
Old 01-19-2010, 02:24 AM
TransAm2002's Avatar
My Z06 is making 572 RWHP and 670 RWTQ on the stock bottom end. These motors are tuff.
Quick Reply: Anyone making 550HP on a stock bottom 346ci???
