98 camaro head swap
98 camaro head swap
Hey. I want to swap the heads on my 98 camaro with 243s from a corvette. Since this year has perimeter-bolt valve covers and single coils, what else do I need for the swap? Thanks
Why not save and swap for a set that will show more gains? Going through a head swap is not a small job and swapping to a set of stock 243s would be a litle waste of time imo.
To answer your question you will need new gaskets, new head bolts, coolant for when you pull the water pump, and a box of band-aids.
because its a 1998, you will need 99+ style valve covers and gaskets and coil pack mounting brackets. or you could get an aftermarket ls1 valve cover and relocate the coil packs.
i would have to agree with 'homerun.' Get an aftermarket set or get those stock 243's ported. I swapped in stock 243's on my 98 T/A and wish i would of waited for a cheap set to pop up....
THANKS- either way there will be extra expense for valve covers, coil packs even with aftermarket heads. You guys are right with saving for better heads, cause then I'll also need a better cam and ...
