problem installing ARP 2.5 inch wheel studs (yes I have searched)
Old 01-20-2010, 08:03 AM
some_punk's Avatar
Default problem installing ARP 2.5 inch wheel studs (yes I have searched)
I have searched around and havent found a way to get the arp #100-7708 2.5 inch studs on the rear. Here is the problem I am having, I was able to remove the wheel speed sensor so I can get the stock studs off. They came out without a problem. But the base diameter of the stock stud is smaller than the ARP. Now I can't get the arp over the reluctor wheel and all the way into the hole. What can I do about this? I dont want to damage the reluctor wheel.
Old 01-20-2010, 10:54 AM
Nsty98LS1's Avatar
it takes some wiggling but they will go. i put 3in or 3.5in studs in a 4 channel car & i did it this way. i believe i even drawed a few through using the lugnuts. i never had a problem with the abs on that car
Old 01-20-2010, 07:41 PM
some_punk's Avatar
I tried wiggling it around and it is still not enough to get it over the reluctor ring. I am going to pull the axle out tonight and try it that way.
Old 01-21-2010, 11:34 AM
twitchtwice's Avatar
i had the same problem on mine. i put mine on a grinder and shaved off a tad bit to get them to fit. no problems so far.
Old 01-24-2010, 01:36 PM
NVR_SPDS's Avatar
I pulled the axles on my 3 channel, and it didnt take long at all to tap out the stock ones, and pull in the 2.5" ARPs.
Old 01-24-2010, 01:55 PM
MikeG's Avatar
I had to do the same for my ARP studs on the front of my car. There was no way I could get them through the stock holes otherwise.
Old 01-24-2010, 10:37 PM
yeah there was no other way. i dont think there are any ill effects to doing this.
Old 01-24-2010, 10:57 PM
Dom
Dom's Avatar
Just pull the axles. I'm glad I did, because I found out I had bad bearings and needed new axles. It won't hurt it to change your rear end oil anyway.
Old 01-25-2010, 01:32 AM
some_punk's Avatar
just kinda pissed off that I just changed the diff fluid 2 years ago to royal purple 75w90 that stuff isnt cheap up here. $25 canadian a bottle. New gasket that I got cheap cause i work at a GM dealer. But I just dont like grinding things. HAs anyone had any broken stud issues because of having to grind it?
