Pontiac Firebird 1967-2002 - water under rear seat?!?
fast?yea
01-20-2010, 01:09 PM
i have quite a bit of water under my drivers side rear seat but no where else any idea how it got there? this really pisses me off
billyb
01-20-2010, 03:59 PM
take the body plug out that is under the seat an let it drain out ,
fast?yea
01-20-2010, 04:11 PM
yep i just did that, i sucked up alot of it with a shop vac the padding on the back of the carpet it still soaked..no ideas how it got in? nothing else is wet.
y2k_ta
01-20-2010, 04:34 PM
You either have a t-top that is leaking, or the hatch is leaking somewhere along the top. If it's a t-top, I'd assume that it is the driver's-side.
fast?yea
01-20-2010, 04:55 PM
i'm thinking its somewhere along the hatch just don't know where,because if it was the ttop i would think the top of the seat would be wet.
Hartje
01-20-2010, 05:03 PM
i found a puddle more than once on the floor boards in the back... my tops and hatch are fine. i have no clue how it gets there... but i thought it was from the floor up through bolt holes and what not. sealed them all up and poof no more water... just a thought... drive through any puddles?
hawk584
01-20-2010, 05:17 PM
do you have brother? maybe someone is playing a joke on you... or the lower rear door seal is bad, maybe a gap between the window seal at the top? pull out a hose, and give your car a bath. put your thumb over the end for some pressure, hit the seams and you should be able to see where it's leaking from... just a suggestion is all
fast?yea
01-20-2010, 06:08 PM
i did the hose thing couldn't really find where it was coming in from. i'm thinking its got to be the top of the hatch cause thats the only way i can see how it would get under the seat.
hawk584
01-20-2010, 06:25 PM
have you folded down the rear seat backing? there might be some evidence of water damage between the seat backing
panterx1
01-21-2010, 11:44 AM
I just finished drying out my drivers side. It was most wet from underneath the rear seat and less wet to my my front floor boards. My driveway is slanted pretty good. I finally noticed that anytime I park with the front of the car downhill and we get a big rain it gets wet. If I park the other way everything is dry. Car doesn't leak when in the car wash. Haven't tried to find the leak other than re-seating the t-tops and rear hatch. I just park with the front uphill. Don't know if this applies to your situation.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
