Any Clutchless transmission racers here Lenco
Lenco
I am running a CS3 Four Speed Lenco....it bolts up like any other SBC bolt pattern except for one hole that makes no difference at all as far as strength or location. I like it over the CS1 I used to run because it is a dimensionally smaller case and weighs a lot less. A CS3 also takes less power to turn....around 10-12 for a CS3 vs 20 or so for a CS1. It takes time to get used to it but they are streetable and there is NO COMPARISON to any other racing transmission out there....although I have heard that Tremec is importing an Australian clutchless 6 speed very soon...supposed to be a nice unit capable of handling high power levels....priced around $7000!
Lenco
They are very streetable. Somehow they got a bad rap that they were not for the street and were racing only units. For example, a Lenco four speed "free wheels" in second and third gear when you back off of the gas. It reengages when you get back on the gas. In fourth gear, it is just like any other four speed. That's it. The other thing to keep in mind is you have to change fluid in the Lenco often as it has no filter and the clutches are continually depositing fine debris in the fluid within the individual cases as you shift gears. For me, changing fluid is no big deal....my car is a Pro Streeter and is not a daily driver. Access is easy and draing and refilling takes 15 minutes. A CS1 can be a little heavy (150 pounds or so for a 4 speed) and take extra power to turn compared to a T56...CS3's are much better. Finally, they are expensive to buy....
Now the positive arguments: You will never buy another manual transmission again no matter how much power you make. I read about supposed "Bullet Proof" manual transmissions (built T-56's, Liberty, Rockland, Jericho,etc)...some are OK and last a few years of hard racing, some are race only where you can't downshift, some shift rough without syncros,etc...
A Lenco shifts as smooth as a hot knife through butter...or as crisp as you like...it depends on how fast you pull the individual shift lever. At 25 mph, I can pull the second gear arm slowly and you would swear it was an automatic car. At full throttle, I can pull that same second gear lever as fast as I can and it barks the tires (it would smoke normal tires but my car is tubbed). I never use the clutch pedal except to start the car in first gear...after that I never touch it again except to come to a stop. I NEVER miss a shift...it is impossible to miss a shift. There is no way to describe how people flock to a car with a Lenco just to see those shifter arms...they don't believe how easy it is to drive when I give them a ride. You can find CS1's used for around $3500...CS2's and CS3's are pricier. They usually don't fit in a stock car without major sheetmetal surgery but who cares...it's a LENCO...I want it to stick out!
Lenco
They have a 5 speed...not overdrive though.....1 to 1 in fifth gear. A sixth gear would mean an additional case. Probably makes the tranny too long...and heavy! See my CS1 4 speed photo....
What clutch are you running?
Kix
Can you down shift easy to pass... I know they make a new street version the st1200..
I don't use a clutch with my faceplated t-56
https://www.youtube.com/watch?v=6eYf...e_gdata_player
Whats the true answer here?
In a t56 the faceplates are laser welded on to OEM t56 gears. Liberty recommends using the clutch because that weld can be a fail point. I quick stab the clutch without moving my right foot on mine just because that's how I've always done it and I'm used to it. To me, I don't see how the shock load is any different between the two as you're basically neutral dropping almost off the limiter during every shift when power shifting with the clutch. Now I can see if you tried to shift it under power without any kind of torque cut.....
that trans in larry larsons car in the video , how does he downshift . What im asking is does he just push a single level forward. I remember hearing that some of those transmissions years ago had to be stopped to get back to first gear.
clutchless, cs1, fluid, lenco, liberty, manual, racing, sale, speed, streetable, t5, t56, tranmisson, transmission, transmissions
