2 bar dry shot
Old 01-22-2010, 10:02 AM
cjg454ss's Avatar
Default 2 bar dry shot
anyone know if this will work. i have a 2 bar map sensor and big injectors. id like to spray a 150 dry shot. i have a mass air but the car is SD tuned. when the nitrous hits it should move above 100-105 kpa in hptuner. kinda like a blower or turbo car. can i add fuel in the 2 bar range for the dry shot? or is there a better way of doing a dry shot with a 2 bar?
Old 01-24-2010, 01:02 PM
Gary Z's Avatar
I can't see any problem. The MAP sensor is only a sensor - it doesn't change anything.
Old 01-24-2010, 01:16 PM
spaz1's Avatar
Just curious why you are running a 2 bar sensor if you arn' t boosted. I can't see how this will work. Not sure how you will get above atmospheric pressure. I think you'll have to use the iat or coolant sensor trick to richen the mixture.
Old 01-24-2010, 01:46 PM
406malibu's Avatar
he is boosted. big single.
Old 01-24-2010, 01:53 PM
spaz1's Avatar
That part of the o/p through me off... I still don't think it will work. I'd use the one of the temp sensors and have the nitrous shut off when in boost with a hobbs switch.
Old 01-24-2010, 04:51 PM
cjg454ss's Avatar
this is for my vette, the last thing the camaro needs is some juice. i think i have it figured out. it might not be boost, but i think it will register over 105kpa. ill have to check to be 100%, even if it registers 110kpa, thats find, under boost enrichment i can richen it up for the shot
Old 01-24-2010, 05:02 PM
spaz1's Avatar
Why not use the Iat?
fuel enrichment table. and a resistor??
Old 01-24-2010, 05:39 PM
Gary Z's Avatar
If you add nitrous then you need to add fuel. It has nothing to do with the 2-Bar MAP sensor. If the question is how should I add fuel with no MAF then I agree the IAT trick is a good method. The IAT trick is better even with a MAF.
Old 01-24-2010, 05:53 PM
spaz1's Avatar
It is still unclear why he is running a 2bar sensor anyway. Could use the coolant sensor too.
Old 01-24-2010, 07:44 PM
ATVracr's Avatar
Nitrous wont raise the KPA like boost does.
Use a maf for 150 shot just make sure it is positioned right and it will work fine.
