diy intake and feels like i lost power
Old 01-23-2010, 09:18 PM
willybuck's Avatar
Default diy intake and feels like i lost power
i made my own intake with small cone filter on the mass and mounted it at the end of the pipe. when i was done it felt like i lost power, didnt pull like it normally does. i was wondering if yal think the filter could be to small and if i should leave the stock air box and cut the inlet hole bigger and run a smooth pipe for tb to mass. thanks
Old 01-23-2010, 09:35 PM
nmp0098's Avatar
I don't know if it's the problem, but when you change the way air hits the MAF sensor you change the way it reads. So you could have lost power because you are running rich or lean and possibly getting spark knock too from the A/F being off. When I swapped my intake manifold, I changed the angle of the bend and it really threw my MAF tune off.
Old 01-24-2010, 07:59 AM
06 SS's Avatar
typically a cone intake like that does two things. It introduces hot air and it causes a lean condition. Hot air is obviosly bad for power and you might be getting knock timing retard from being too lean/hot in the cylinders. Scan for knock before doing anything else.
Old 01-24-2010, 10:39 AM
SSGoat's Avatar
i did the same thing before my k&n and yes i agree it did feel like it lost a bit of power sometimes but also like it gained power other times... when i just started in the mornings itd feel a lil more powerful, after a full day it felt a lil slow so yes its the hot air..
Old 01-24-2010, 03:19 PM
JDMC5's Avatar
It's either your design or your tune. Your tune is almost definitely off. What are the dimensions of your design?
Old 01-24-2010, 03:41 PM
willybuck's Avatar
well today i took the filter off and it felt alot better good throttle response and power. did some mod. to the filter and put it back on and loses power. i think the filter is just not enough for the air demand and it is just a cheap advance cone filter too.
Old 01-25-2010, 11:16 AM
Tappeter's Avatar
Always get the best quality and largest cone filter you can fit. ALSO:: Very Important:
Do NOT make up a filter set up like the cheapo ones you see on ebay, with the filter just stuck on the end of the MAF sensor out in the open engine bay. Your just sucking in HOT air, its worse then the OEM set up. You need to isolate the filter from the engine bay heat, use or make an air box that's open in the front. I made an insulated aluminum box with a clear lexan cover.
Old 01-25-2010, 03:03 PM
AlabamaGuy's Avatar
This is why products such as K&N are actually worth the money they ask for them. The amount of R&D and quality of materials as well as production processes put into products by these major corporations is very difficult to match by a DIYer. I say difficult because it can be done, it's just not the easiest thing in the world to do.
Old 01-25-2010, 05:07 PM
hexxLS4's Avatar
Agreed...this would be a good opportunity to get a CAI intake for $150 (cheap!!): https://ls1tech.com/forums/ls4-front...your-pick.html
Old 01-25-2010, 05:18 PM
LS1Tech Sponsor
06MonteSS's Avatar
yeah, buy Hexx's CAI box... you can't beat it! and that's a VERY good price for it...
I have one on my Monte... works great...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Quick Reply: diy intake and feels like i lost power
