Sponsor Group Purchases - Strange and Moser rear end GP
Kaltech Tuning
01-28-2010, 08:49 PM
With tax money on the way it's time for another rearend gp. Same deal as usual this is good for Strange and Moser rearends. I'm offering free shipping ($175 - $250) and a few bucks off beyond that. Let me know what you're looking for and I'll give you a quote.
Basic info I need when you request a quote:
Year and model of the car
ABS? 3 channel (no traction control) or 4 channel (with tcs)
Desired gear ratio
Desired differential
Any additional options you know that you want.
Update for GP starting on 2/10/11
Commitments:
Steve P.
Dan S.
Ed M.
Joe G.
Byron N.
Omar R.
This is a go!!!
allan808
01-29-2010, 03:10 AM
im looking for a direct bolt in for a 98 trans am,373 gears and a diff that i can use street/strip...price?thanks
OldskOOL01z28
01-29-2010, 06:37 AM
Im interested in the GP Im looking for a strange s60
what price for the following
Strange s60 for 2001 Z28 M6
3 channel ABS only
Backing plates
3.90 gears
Detroit locker
35 spline
Stock with
Also for a matching drive shaft, as I believe stock length will not fit?
Thanks
TransAmatt99
01-29-2010, 11:27 AM
I would like a price on an S60.
1999 Camaro
4 channel
3.73 gears with the truetrac
stock width
with new backing plates
35 spline axles
and a shortened driveshaft
Thanks
LS1powerhouse02
01-29-2010, 12:50 PM
Price on 9" and S60 both with driveshafts please.
Year and model of the car - 2002 Camaro Z28
ABS? 3 channel (no traction control) or 4 channel (with tcs) - 3 channel
Desired gear ratio - 4.10
Desired differential - price on spool and tru-trac please
Any additional options you know that you want. - LCA brackets welded on.
Thanks!
Brent
CamdLS1'00SS
01-29-2010, 06:08 PM
S60 w/35 spline axles
2000 Camaro
4 channel ABS
4.56's
Tru-Trac
support cover, non-powdercoated; LCA brackets welded on, stock width
to 06810
98LS1Kid
01-29-2010, 09:02 PM
1998 Camaro
4 channel rear end
4.10 gears with the truetrac
stock width
35 spline axles
Shipped to 98685
Thanks
therealthatguy
01-29-2010, 09:11 PM
moser 9"
2000 camaro
4 channel
3.73's
detroit locker
LCA relocation brackets welded on??
shortened??
33 spline
+badss+
01-29-2010, 10:15 PM
price on a moser 9 in.
2002 camaro a4
3.70 gear nodular center
relocation brackets
35 spline 4 channel reusing stock backing plates
and the best street/strip locker/spool/truetrack for car with 4l60e and 4000 stall
narrowed 1.0 each side
thanks.. zip is 32909
jb7241986
01-30-2010, 12:23 AM
strange dana s60. 35 spline. 3:73 gears, stock width. 4 channel abs. trac loc heavy duty posi. 2002 camaro ss. you guys make driveshafts for this i heard with the s60 you had to shorten the driveshaft.
76SILVERADO
01-30-2010, 06:33 AM
Price on 9", 12 bolt and S60
2002 Camaro SS
Desired gear ratio - 3.42
Desired differential - tru-trac HD
Stock width
Bigpapa_TA
01-30-2010, 11:19 AM
moser 9"
2000 camaro
4 channel
3.73's
detroit locker
shortened??
33 spline
x2 except its for a 99 Trans Am
omcar
01-30-2010, 12:06 PM
car= 2001 formula
price on strange 12 bolt
3 channel
spool
35 spline axles
3.73
thanks
1fastws6_02
01-30-2010, 08:09 PM
can i get just the housing and 35 spline axle kit 9" braced drain and fill narrowed 3" per side no abs or trac cont gundrilled wit 5/8 studs ? oh and powder coated black.
if so how much ?
Thanks
SLP4CamaroSS
01-30-2010, 09:34 PM
need quote on moser housing and axels , 31spline, drain and fill plug, stock length, lca brackets welded on
00 camaro ss
som6969
01-31-2010, 02:18 AM
With tax money on the way it's time for another rearend gp. Same deal as usual this is good for Strange and Moser rearends. I'm offering free shipping ($150 - 175) and a few bucks off beyond that. Let me know what you're looking for and I'll give you a quote.
Desired gear ratio
Need a quote for a S60
2000 Pontiac Trans Am 6speed
4 channel ABS/TCS
4.10 gears
35 Spline axles
spool
Stock brakes
Thanks
1baddls1
01-31-2010, 09:54 PM
bump for good deal from an even better guy
ss4life1986
01-31-2010, 10:56 PM
strange 12 bolt
2002 Camaro SS
Desired differential - trutrac/eaton
XtremeDime
02-01-2010, 04:42 AM
9" housing, 2 channel, 31 spline axles and center(what centers do you have?) 3.70s w/posi. thanks
waggz
02-01-2010, 08:47 AM
Year and model of the car 2000 Trans Am
ABS? 3 channel (no traction control) or 4 channel (with tcs) 3Channel
Desired gear ratio 373
Desired differential eaton
Axles show me my options and prices please
I am looking for a quote on a strange and moser if possible
Kaltech Tuning
02-01-2010, 06:50 PM
All requests to this point have been responded to.
ABQ99TA
02-01-2010, 07:32 PM
Moser 9
1999 TA
4 channel
3.89
TruTrac
LCAs welded, Drive shaft to fit and TA mount
Kaltech Tuning
02-02-2010, 01:44 PM
All requests responded to.
00T/AWS6
02-02-2010, 03:04 PM
Strange 12 bolt and 9"
Don't need ABS or Trac Control
Aluminum center Spool
4.30 gears, Backbraced, Plugs
35 spline gun drilled axles
With moly DS and loop
Grifter
02-03-2010, 03:05 PM
PM sent.
nm2769
02-03-2010, 04:53 PM
Price on 9" with driveshaft please.
Year and model of the car - 2002 Camaro SS
Desired gear ratio - 3.90
Desired differential - Detroit locker and tru-trac please
kikass_z28
02-03-2010, 08:32 PM
s60 35 spline stock width
Year and model of the car- 1991 camaro
ABS? 3 channel (no traction control) or 4 channel (with tcs)- no
Desired gear ratio- 4.10
Desired differential- tru-trac
Any additional options you know that you want. - shortened driveshaft, welded on lca relo brackets, backing plates for 98-02 brakes, aluminum girdle cover, chrome moly pinion yoke
Will I need a conversion U-joint?
Kaltech Tuning
02-03-2010, 08:46 PM
JC70SS
02-04-2010, 05:23 PM
looking for Strange 12 bolt
3 channel
4.10 with eaton posi
33 spline axles
Kaltech Tuning
02-04-2010, 07:12 PM
Responses sent.
UrSmked
02-10-2010, 10:22 AM
quote on a 2000 trans am. 9 in. or S60, 4 channel, 4.11 gears, spool, narrowed 2.5" off each side, 35 spline. Price both please.
MacGyver
02-11-2010, 10:59 AM
Moser 9"
99 Trans am
No ABS
3.70 Gears Nodular Center
35 spline spool
Fill and drain plugs
LCA brackets welded
Shipped to 32725
+badss+
02-11-2010, 02:51 PM
Year and model of the car 2002 camaro ss
ABS? 3 channel (no traction control) or 4 channel (with tcs) 4 channel
Desired gear ratio 3.73
Desired differential 35 spline with spool
12mm long studs
reusing backing plates
drain and fill
shipped to 32909
Kaltech Tuning
02-11-2010, 06:23 PM
PM's sent
quik01ss
02-11-2010, 06:46 PM
2001 CamaroSS
-Moser 12 bolt
3 Channel
4.11 Gear
31 Spline
Tru-Trac
Stock Length
Alum. Rear cover
Thanks
LS1powerhouse02
02-11-2010, 07:11 PM
Strange 12 bolt
4.10 gears
Eaton posi
3 channel
Rear girdle
and upgraded DS
for a 2002 Z28.
C0wb0y
02-11-2010, 09:22 PM
97 Camaro
No ABS No traction control
4.11 gear ratio
35 spool
Tru Trac
Kaltech Tuning
02-15-2010, 11:03 AM
All requests and questions answered.
Franklin
02-15-2010, 05:55 PM
2002 Camaro SS 4 channel
S60, 4.10 gear, with LCA brackets welded on, Aluminum cover, truetrac
poopman
02-16-2010, 12:15 PM
12 bolt or s60
97 z
3 channel
4:10 eaton or true trac
welded lcas
Kaltech Tuning
02-16-2010, 01:34 PM
Requests answered.
Dskeet6
02-17-2010, 07:51 AM
Dana s60
ABS? 3 channel (no traction control) or 4 channel (with tcs) NO ABS 3 channel
Desired gear ratio 3.42 or 3.55 somewhere around there
Desired differential Tru-trac
shipped to 19085
Thanks Kaltech
mike13
02-17-2010, 08:34 AM
1999 trans am
12 bolt tru-trac 3.25 gears
4ch abs
stock bracket mounts
shipped to 98391
Thank You
Kaltech Tuning
02-17-2010, 11:36 AM
Replies sent.
jhanner
02-17-2010, 12:22 PM
id like a price on a 9inch 35 spline 4 channel with no internals just shafts
Kaltech Tuning
02-17-2010, 03:54 PM
Responses sent.
spaulsen
02-17-2010, 04:38 PM
1998 Camaro
3 channel
stock width
35 spline axles
new backing plates
new drive shaft
newark ohio 43055
Thanks
Kaltech Tuning
02-17-2010, 04:46 PM
PM Sent
DarkFormula
02-17-2010, 06:07 PM
12-bolt
3.73s
Posi
Extended lugs
31 spline
4-channel
Aluminum cover with plugs
Sway bar brackets
2000KnightRider
02-17-2010, 09:24 PM
How much for Strange 12 bolt or S60
2000 T/A
12 Bolt (less brakes)-33 Spline, 3.73 gears, SS Posi with reluctor ring, backing plates, 4-channel. stock length. Be able to fit stock torque arm
S60- True Track, 35 spline, 3.90 gears, Backing Plates, 4-channel, ABS Reluctor Rings. stock length. Be able to fit stock torque arm. How much for custom DS with it?
Kaltech Tuning
02-18-2010, 07:27 PM
Replies sent.
Blackmagic65ss
02-19-2010, 02:59 PM
I need a qoute on an s60 and a 9". I want a limited slip differential and a gear around the 4.10 range. It's a 98 z/28 with the 4 channel rear. Please respond to poweraddr@yahoo.com . Thank you.
Kaltech Tuning
02-19-2010, 09:20 PM
Responses sent.
raginazn616
02-20-2010, 10:02 PM
pm sent
knight17Z
02-21-2010, 05:13 AM
Year and model of the car - 1995 Camaro Z28
Desired gear ratio - 3.73
who_needs_maf?
02-21-2010, 06:02 PM
95 Z28
moser 9 inch
No abs
3.90 gear
full spool
drain and fill plugs
narrowed 2" on each side
33 spline axles
thanks!
JB_97ws6TA
02-21-2010, 07:11 PM
Can I please have a quote for the following...
Year and model of the car 1997 Trans Am
ABS? 3 channel (no traction control) or 4 channel (with tcs)3 Channel
Desired gear ratio 4.10
Desired differential TruTrac
Thanks,
JB
Kaltech Tuning
02-22-2010, 10:06 PM
Replies Sent.
Razmiblackz28
02-22-2010, 10:49 PM
1998 Camaro SS
4.11
Trutrac
TxAgWS6
02-23-2010, 12:55 AM
Need a quote for 9", 12 bolt, and S60, with drive shafts if needed.
need direct bolt in with all mounts for a stock suspension 2000 Trans Am M6
4 channel ABS
3.73 gear or 3.70 if 9"
best street/ light strip duty strong center, no spools
stock width, can reuse my stock brake setup
need wheel studs slightly longer than stock, about 3/8 to 1/2 in longer
want a rear i cant break on the street tires, and unlikely to break with 450 whp on slicks with an M6, would like to not be able to hear it screaming inside the car on deceleration too, thanks
sujomatt
02-23-2010, 09:44 AM
Looking for a quote for the following:
99 Camaro z28
Strange S60
3.42 gears / TruTrac
Don't need ABS or TCS
Driveshaft
All necessary parts to have it be direct bolt in
to 06033
thx!
00 black ss
02-23-2010, 11:13 AM
2000 ss. 9 inch 4 channel 4.30s, lca relocation, bmr anti drag bar brackets, drain n fill plug,. can i get a quote with a spool and locker? trying to debate btw the to. also im on the island so i dont need shipping i dont know if u can nock that 175 off the price?
Kaltech Tuning
02-23-2010, 02:24 PM
Responses sent.
coldblooded
03-04-2010, 06:15 PM
02 SS M9
No ABS
4.11's
Full spool
33 spline Plugs- drain/fill LCA's welded on
EDIT: shipped to 20794
Franklin
03-04-2010, 06:58 PM
I ordered my S60 with 4:10's. Can't wait for it to get here and smoke the tires!!!!
Kaltech Tuning
03-05-2010, 01:37 PM
Thanks for the order, you should enjoy it quite a bit.
jsafe
03-05-2010, 03:28 PM
9 inch 4 channel 3.70s, lca relocation, , drain n fill plug,. can i get a quote with a locker?
Z28/2002
03-05-2010, 05:26 PM
Car is a 2002 Trans Am
Need a quote for 9", 12 bolt, and S60, all drive shafts for a TH350.
NO TCS/ NO ABS
3.90 and 4.11 gears
tru trac or detroit locker
stock width with and without backing plates
fill/drain plug, lca relocation
Shipped to a business at 45694
wrencher
03-05-2010, 10:18 PM
2k camaro
9 inch 4.11's, trutrac, 3 channel abs
ws6fitz
03-06-2010, 09:35 PM
01 trans am
12 bolt wanted
3.73 gear with posi
4 channel
33 or 35 spline
thanks
Tudds
03-07-2010, 04:34 PM
Thanks for the 12 bolt. Great customer service from Kaltech!!
02SLPCAMARO23
03-08-2010, 09:27 AM
This still going on?? if so..
2002 camaro
S60
4 channel
4.10
locker
35 spline
w/ drive shaft
shipped to 28314
Kaltech Tuning
03-08-2010, 08:25 PM
All responses sent.
AngeloWS6
03-08-2010, 08:37 PM
2002 WS6
moser 12
w/abs
4.10
locker
35 spline
w/ drive shaft
shipped to 79934
Camario
03-09-2010, 07:52 AM
2001 Camaro m6
moser 9in
31 spline
4 channel
3.89 gear ratio
iron case and cost for aluminum
lca reloc brackets
trac-loc
drain and xtra fill plug
shipped to 60463
thanks in advance!
Kaltech Tuning
03-09-2010, 08:08 AM
Responses sent.
fucter
03-09-2010, 09:26 PM
moser 9"
2000 camaro SS
4 channel (ABS and TCS)
4.11's
tru trac
31 spline
zip 72758
Kaltech Tuning
03-10-2010, 07:53 AM
Replies sent.
Orangemagic
03-10-2010, 09:23 PM
1999 Trans am
4:10 gear
Spool
4 channel
12 bolt or 9" Whatevers cheap
lca welded on
Norway
03-12-2010, 01:19 AM
need a quote for a
2001 Camaro Z-28 M6
*S60
*4.10 Gears
*truetrac
*3-channel ABS
*need direct bolt in with all mounts
*driveshaft, lca reloc brackets, backing plates included
Kaltech Tuning
03-12-2010, 08:41 AM
Responses sent.
2000 Formula A4
Moser 9" - Stock Width
No Traction Control
Backing Plates
3.73 Gear
Detroit Locker
35 Spline Axles
Reolcation Brackets
Drain & Fill plugs
To 27530 zip
Qwick98Z
03-16-2010, 07:12 PM
1998 camaro Z28
Strange 12 bolt
no abs
spool
4.10's
Thank you.
feelnlo
03-17-2010, 02:03 AM
98 Camaro z28
Strange S60
Narrowed 3" per side
4 channel ABS/TCS
3.90's --(What brand gears are available? What ratios are available?)
Eaton TrueTrac --(What brand differentials are available?)
E-brake cable mounting brackets welded on
Brake line brackets welded on
Does the housing come bare, or painted?
Shipped to zip 39402
OldskOOL01z28
03-19-2010, 06:30 PM
Just got my new strange s60 and driveshaft delivered to my shop can't wait to put it in :D. Thanks to Brian at Kaltech, you won't find a better deal!
rubenxx
03-19-2010, 10:57 PM
2001 Camaro z28 M6
3 channel
4.10 gears with truetrac
stock width
35 spline axles
new backing plates
new drive shaft
welded LCA's
ready to bolt in
And does the S cover cost extra?
shipped to 98053
second_2_none
03-20-2010, 08:53 AM
Quote on an S60 please
Year and model of the car - 99'
ABS? 3 channel (no traction control) or 4 channel (with tcs) - 4 channel
Desired gear ratio - 3:73
Desired differential - true trac
Any additional options you know that you want - relocation lca brackets welded on.
backing plates
new drive shaft
35 spline axles
shipped to 28348
second_2_none
03-21-2010, 09:13 AM
Are you guys even offering this anymore? I really need a rear end and cant wait much longer.
dlross
03-21-2010, 09:19 AM
Me too price on that same set.
Kaltech Tuning
03-21-2010, 11:16 AM
Very nice!!! Enjoy it and thank you for the purchase.
All other requests have been sent via PM.
69_YENKO
03-21-2010, 02:24 PM
Moser 9"
2001 camaro
4 channel
3.73's
detroit locker
narrowed 2" per side
33 spline
also price with spool
panterx1
03-21-2010, 04:00 PM
Price on an S60.
2001 Camaro M6
4 channel
Stock width
35 spline axles
New backing plates
Aluminum cover
New drive shaft
Welded LCA's
Ready to bolt in
Shipped to 77546
Thanks,
Jim
Kaltech Tuning
03-22-2010, 08:45 PM
PM's sent
Wheels_78
03-24-2010, 07:27 PM
s60
99 TA
35 spline
tru trak
3.73
4 channel
new backing plates / reluctors
stock lugs
All new mounts and brackets for the Fbody
4l60e compatible drive shaft capable of holding as much power as the rear will
98z-28redcamaro
03-24-2010, 08:29 PM
9in
3.73
4channel abs
spool
35 spline
A Str8 Up G
03-24-2010, 09:14 PM
2002 Trans Am M6
Moser 9" stock width
4 channel abs/tc
33 spline axles
spool
lca brackets
sway bar brackets
powder coated black
3.42
drain plug
12mm studs (or largest that still fits stock rims)
Kaltech Tuning
03-25-2010, 09:55 PM
Responses sent.
Reject
03-29-2010, 05:09 PM
9"
no abs
spool w/ 3.23
35 spline
backbrace
SINISTER-TA
03-30-2010, 01:58 PM
9 inch
trutrac/3.50
LCA brackets
sway bar brackes
dcvingv6
03-30-2010, 05:23 PM
Hi,
Looking for the following:
Moser 9" full spool for 2001 trans am, stock width
Standard Finish
35 Spline Axles
4 Channel
3.75 Gears
Drain Plug
Stock Style sway bar brackets welded on
Standard Axles
Stock wheel stud's
NO back-brace
Also would be looking for a driveshaft, 3.5 PST for an M6, or similar.
Looking for total out the door price shipped to central NY (13090)
Thank you in advanced...
--Mike
Patsy57
04-01-2010, 12:55 PM
2002 TA WS6
3 Channel abs
4.11
Trutrac
35 spline axels
Aluminum cover
Kaltech Tuning
04-01-2010, 02:55 PM
Responses sent.
ssowned
04-01-2010, 07:11 PM
Please price out the Dana S60 Rear End:
Car: 2001 Camaro SS M6
4 channel ABS
3.90 gears with truetrac
stock width
35 spline axles
new drive shaft
ready to bolt in
shipped to 85041
Numba1Stunna
04-01-2010, 10:11 PM
2002 Camaro SS
4 channel (with tcs) new reluctor rings
Desired gear ratio - 3.90 or 4.10 or 4.11
Stock width
shipped to 02769
Kaltech Tuning
04-03-2010, 11:21 AM
Responses sent.
9" and 12 bolt
1996 Z28
has abs
not sure if its a 3 channel or 4 channel it has no TCS
3.55 or 3.73
Tru Trac
35 Spline axles
shipped to 75087
airforcemanss
04-04-2010, 02:06 AM
9"
3 channel
abs
3.73's
airforcemanss
04-04-2010, 02:10 AM
9"
3 channel
spool 35 spline
with and without abs
3.73's/ 3.89's
lca's welded on or additional adj. holes
drain fill plug etc...
Kaltech Tuning
04-04-2010, 10:51 AM
Responses sent
nazztman4739
04-04-2010, 01:52 PM
2001 ss camaro price on a budget rear posi with tcs and something between 3.73-4.11 range
2001 SS.....S60
3 Channel
3.73 with true trac
add strange driveshaft
add black strange differential cover
black powdercoat (does strange do that??)
LCA relocation brackets??
zip is 39532
slowec
04-05-2010, 06:30 AM
Price on a s60
98 Z28
no abs
3.73 tru trac
35 spline
drive shaft
adjustable torque arm and lca
Eddie.ci
04-05-2010, 06:53 PM
1998 z28, 3 channel, stock width, 3.90 gears, & driveshaft, true trac
price on dana 60, and 9in.
Shipped to 07740
Kaltech Tuning
04-05-2010, 07:53 PM
responses sent.
dcvingv6
04-08-2010, 09:17 PM
Ordered today... thanks guys!
DanDan
04-12-2010, 02:16 PM
1999 Firehawk Transam
3 channel (no tcs)
3:42
spool
Gregorya24
04-12-2010, 02:52 PM
can you do a axle and housing only?
barkingspud
04-12-2010, 05:00 PM
2004-2006 GTO M9 (Kit)
Backbrace
Wildwood Drag Brakes w/Drilled Rotors
Aluminum Thru Bolt Center Section
40 Spline Axles w/Spool
Gun Drilled/Flanged Axles
5/8" Studs
Powder Coated Housing
Obviously, you're going to need to call the good folks at Moser as this isn't a part number yet but it is available. Thanks in advance!
quik01ss
04-13-2010, 01:40 AM
Got my S60 rear end today and painted assembled and installed it what a deal came right to me residential door and straight into my garage no more breaking my 10bolt!
qc97z
04-13-2010, 09:48 AM
Please quote for me:
for '97 Z28 M6
Strange 12 bolt
4 Channel (ABS w/TCS)
33 spline axles
3.90 gears
Quote both Eaton posi and TrueTrac HD
Drain/Fill plugs
Painted or powdercoated black.
Thanks!
kornboy
04-18-2010, 12:00 AM
price on strange12bolt please
99 camaro
no abs
342gm gears
spool
must be bolt in ready
48532 zip code
xRelapse13
04-18-2010, 12:28 PM
2000 Trans Am
Strange 9"
3 Channel
Wavetrac
Welded LCA relos
Drain and Fill Plug
Driveshaft to match
Long style TQ arm (tranny Mount)
Stock Brake backing plates
Stock swaybar mounts
E brake cable mounting bracket welded on
brake line brackets welded on
Ready to bolt in
Quiet Gears also
Pricing on options for lightening it.
Kaltech Tuning
04-18-2010, 04:12 PM
Responses sent. Barkingspud I'll be getting in touch with you soon.
dcvingv6
04-19-2010, 05:24 PM
Just wanted to give props to Kaltech!!!
I received the rear on Friday, and the driveshaft will be here tomorrow, 11 days from the order placement.
Great turn around time, price, and Customer Service, which sometimes is lacking in businesses these days.
Thanks a lot guys...
--Mike
whiteboycntdnce
04-21-2010, 12:20 AM
9" stock width
2000 Camaro
3 Channel
3.50
TrueTrac
31 spline
shipping to 23237
Thanks!
grifter757
04-21-2010, 11:02 AM
Price on 9"and S60
87 Camaro IROC
Welded LCA reloc
Drain and Fill Plug
Driveshaft to match
Ready to bolt in
blue by you
04-22-2010, 06:56 AM
Price on a 9" and S60
1998 Trans Am
4 Channel
4.10's
With driveshafts
53581 zip
Thanks!
Loudmouth LS1
04-24-2010, 08:49 AM
Price on a 9" (whichever is cheaper, moser or strange, doesn't matter) for 99 camaro torque arm car with 35 spline axles, housing and axles package, no center section. Back brace, no abs, fill and drain plugs installed, lca relocation brackets installed, and 5/8" x 3" studs as the options. Also, don't know if you can, but I need the pads welded on the rear to mount my bmr extreme duty anti-roll bar to, if not, i'll buy them and weld them on myself. What is the most it can be narrowed on each side without interfering with the stock lca mounting points? I wanted 4" each side so I could run a 15x10 3.5" backspacing rim to get a nice deep dish rim back there, but I heard somewhere you can only do 3" per side. Let me know a price, I just sold my 12-bolt and am ready to order, thanks alot, appreciate it!
z28josh
04-24-2010, 09:19 AM
price for
2000 z28 camaro 6 spd
strange Dana s60
4 chanel
3.73 ratio
true trac
35 spline
with and without a shorted driveshaft
Thank you
__________________
Kaltech Tuning
04-25-2010, 07:10 PM
Responses sent
Blu99T/A
04-25-2010, 08:17 PM
I am looking for the Strange 60 (stock width) for my 99 Pontiac Trans Am.
4 Channel
Trutrac
4.11's
1350 yoke
Aluminum diff cover
Prices with and without the the Driveshaft would be great. Prefer chromoly for the driveshaft.
I can send in my backing plates, etc as it is not my primary driver.
DionM
04-26-2010, 05:56 AM
Price on a 12 bolt housing and Axles
1968 Camaro
Multileaf
Big Bearing Ford Flush mount ends ( for LS1 style disk brakes )
I need the overall length to be 58.75 from flange to flange.
Shipped to 27253
Thanks, Dion
buzz12586
04-27-2010, 12:18 PM
1995 Camaro
Strange S60
3.73 gears
Spool
35 spline axles
no abs or tc
shipped to 28227.
Thanks...
slowec
04-28-2010, 04:11 AM
Price on a s60
98 Z28
no abs
3.73 tru trac
35 spline
drive shaft
need a quote please...
jmm98LS1
04-28-2010, 09:09 AM
Price quote please:
-'98 camaro
-moser 9" housing/axle package only
-35 spline axles
-no abs/tcs
-12mm long wheel studs
-narrowed 3" per side
-no sway bar brackets
-bare steel
-LCA relocation brackets welded on
-drain/fill plugs added
Thanks!
buzz12586
04-29-2010, 09:18 AM
Bump for this....
Blu99T/A
04-29-2010, 05:09 PM
4 Channel
Trutrac
4.11's
1350 yoke
Aluminum diff cover
:confused:
Anything?
kornboy
04-30-2010, 05:32 PM
I can't wait for 3 more weeks.I want it now!!!
ssowned
05-02-2010, 01:05 PM
Mine will be coming this next week =)
corvet786c
05-02-2010, 03:31 PM
I would like a quote for an strange 12 bolt
its on a 2000 trans am 6 speed
options:
4:10's
detroit locker
aluminum cover
3 channel abs
chrom moly yoke
33 spline
Anything else u think I might need. The car is a DD driver and take to track occasionally.
Or whatever would work best for me also best price please.
Kaltech Tuning
05-02-2010, 07:43 PM
Responses sent. I'd like to get all of the orders in by May 14th. Thanks.
02SSLE
05-02-2010, 10:22 PM
Price on Dana 60 and 9 inch
2000 Firebird
3 channel no traction control
3.90 gear or close
KW4life06
05-04-2010, 01:50 AM
price on an S60 for 2000 camaro
3 channel abs and 4 channel both prices
3.90 gear
trutrac
?'s on narrowing $, if same 1 inch on each side
35 spline
bigcraig987
05-04-2010, 07:50 PM
Quote for:
99 Trans Am
Strange 12 bolt
4 channel
posi
33 spline
3.73 gear
aluminum cover
drain/fill plugs
Campton
05-08-2010, 09:02 AM
You still doing this?
1998 camaro
No ABS
gear ratio:3.54
Full Locker or True Track is full locker not an option
35 spline
sidewayz28
05-10-2010, 12:45 AM
2001 Camaro
Strange S60
No ABS
3.73s
35 Spline axles
spool
2" narrowed each side
cover, drain/fill plugs, assembled
shipped to 98115
*i want to order this week!!!!*
Kaltech Tuning
05-10-2010, 08:13 AM
Responses sent. I'm wrapping this gp up this week. Requests need to be in by friday the 14th and orders need to be placed by friday the 21st.
01wssick
05-11-2010, 08:05 PM
Price on Strange and moser 12 Bolt
01 WS6
33 Spline
3 Channel
Posi
4.56 gears
Drain/Fill plugs.
Ready to go in.
Kaltech Tuning
05-11-2010, 09:35 PM
Response sent
racekat21
05-12-2010, 12:06 PM
are you doing this special only on f-bodys?
if not could or do you have any for a s-10?
z28241
05-12-2010, 11:59 PM
Quote please
02 Trans Am WS6
Moser M9
3 channell
4.10 gear
LCA's mounted
33 spline
Also a quote on
Adjustable Torque Arm
Kaltech Tuning
05-13-2010, 09:04 AM
Responses sent.
corvet786c
05-16-2010, 08:41 PM
Hey how much for an Strange 12 bolt with posi 3.90 gears aluminum cover 3channel abs with shipping? My vehicle is a 2000 regular trans am LS1 with 430 rwhp 6 speed.
The_Bishop
05-17-2010, 06:54 PM
Am I too late?
Strange 12 bolt with 3.73 gears, Eaton posi, 3 channel ABS for a 1998 Camaro Z28.
Also, pricing on the same thing but a S60.
Razmiblackz28
06-07-2010, 11:51 AM
Is there still time for me to get in on this!
wradcli
02-10-2011, 12:35 PM
Moser 12 bolt
1999 Camaro
Trac Control
Disc Brakes
Need
390 gears
Eaton Posi
Relocation bracket
Send in backing plates
Aluminum cover
Sway bar?
33 spline
wradcli
02-10-2011, 12:36 PM
Opps didnt see date
ls1blazer
02-11-2011, 04:45 PM
Time for another tax return gp ! I need a 9", 60" (outside drum to drum) ,plain housing,tru trac carrier,no abs,31 spline axles,5"x4 3/4",3.89 gears,1999 Gm S10 drum brakes (It's going in a geo.)
Pewter53
02-12-2011, 12:10 AM
strange and moser 12 bolt
stock width
3.73
3 channel
31 or 33 spline
non powder coated
sxracerb25
02-12-2011, 06:22 AM
Moser 9"
2000 Trams Am
No channels
4.30
Quote for Wavetrac and tru trac
Backbrace
Black powder coated
LCA Relocation Brackets
Sway bar brackets
Drain and fill plugs
Thanks
Kaltech Tuning
02-13-2011, 08:46 PM
Ok, we'll fire this one up again. As usual per GP rules we'll need 6 purchases to make this a go.
25thhawk
02-15-2011, 03:58 PM
Can I get a price for an S-60, 4.30 gear, trutrac, aluminum cover, 4 channel, with new backing plates, cromoly yoke. Also need a cromoly driveshaft with a forged or cromoly yoke. Shipped to 18337. Thanks
+badss+
02-15-2011, 07:27 PM
may i get a quote for a s60 4 channel with my backing plates true trac with yukon 3.70 gears strange chromoly drive shaft set for 2002 camaro ss with 4l80e trans 35 spline axles and upgraded yoke.
thanks shipped to a business address 32904
Kaltech Tuning
02-15-2011, 08:14 PM
Responses sent.
joeytransam
02-17-2011, 04:06 AM
I have a 2002 ws6 what would it cost for a s60 with 4.10 true track 4 channel abs backing plates also what is a detroit locker and what does it cost? i would also need the driveshaft to go with it also can the whole rear be powder coated or just the cover? im in merrick 11566
Kaltech Tuning
02-17-2011, 08:43 AM
Responses sent.
TurbopigB4C
02-17-2011, 04:35 PM
1999 Camaro
No ABS
4.30 Ratio
Strange S60
5/8" studs OPRS12
Aluminum Powdercoat OPRS08
Locker OPRS23
Send in my Backing Plates
Kaltech Tuning
02-17-2011, 08:11 PM
Message sent.
midnight99ss
02-19-2011, 06:23 PM
99Camaro
9" w/ back brace, stock width
3 channel (not required)
stock brakes
3.70-3.89 lightened gears
Wave-trac or det locker
fill cap
powder coated
iron ctr section
forged alumn pinion supt
strange axles
arp 2.5" studs
bearcatt
02-20-2011, 03:53 AM
Two quotes please:
2000 Pontiac Firebird Formula.
Strange S60
Stock Size Studs 12mm x 1.5
Gear Ratio 3.73
4 channel ABS with reluctor rings
35 Spline True Trac
Stock Brakes
New Backing Plates
Pinion Yoke Chromoly
** New Shorter Compatible Drive Shaft **
Shipping address: 91001
Strange 12Bolt
Gear Ratio 3.42
35 Spline Eaton Posi
Stock Brakes
New Backing Plates
Upgraded Aluminum Cover
** Conversion U-Joint - Stock 3R to 1350 **
silversrtman
02-21-2011, 09:42 PM
2000 Camaro SS
Strange S60
Gear Ratio 3.73 (or 4.10 still deciding)
35 Spline True Trac
Stock Brakes
New Backing Plates (or not still deciding)
Driveshaft
Shipped to 10512
1baddls1
02-22-2011, 10:57 AM
oh yeah tax timeeeeeee
ttt for a great shop
Kaltech Tuning
02-23-2011, 06:01 AM
Responses sent.
allblackSS
02-24-2011, 11:05 AM
Hey man can i get a quote ona 9inch with 4 channel 3.89 or 3.90 gears true trac locker oil drain plug 35 spline axles to 42134
thanks
Bubba
chm2001z
02-24-2011, 05:42 PM
2001 camaro
strange s60
stock studs
4.10 gears
3 channel
new backing plates
35 spline
truetrac
shipped 63016
358chevycamaro
02-28-2011, 03:03 AM
Can you do a discount on a set of custom axles, aluminum center section, lightweight spool, etc? I already have a custom chromolly housing.
Kaltech Tuning
02-28-2011, 05:32 PM
Responses sent.
blue by you
03-02-2011, 09:23 PM
S60, 4.10's, 4 channel ABS, stock studs, no backing plates, tru-trac and driveshaft for 1998 T/A with a 6 speed. Thanks, Jess
Kaltech Tuning
03-03-2011, 07:18 AM
Quotes sent
Golf&GM
03-03-2011, 01:35 PM
PM sent, let me know if you need more info on my setup!
Kaltech Tuning
03-03-2011, 07:30 PM
Quotes sent.
transbird95
03-03-2011, 07:35 PM
Hello, you have a pm..
xtransxamx
03-04-2011, 05:29 PM
Brian - will call monday
fatboyzcamaro
03-04-2011, 08:57 PM
hello i would like two quotes please sir.
9 inch rear
35 axle
lca relocation brkt
stock length
1/2 studs
full spool
4:30 gears
my stock rear is a 4 channel but i dont need no abs sir.
rear fully ready to bolt in car with my brakes and plates.
s60
35 spline pro race strange axles
rear oil
lca relocation brkt
1350 yoke
stock length
full spool
4:10 gear
c/m yoke
ready to bolt n car with my backing plates and brakes.
how much are new backing plates for either rear.thanks in advance.
92gearhead
03-05-2011, 07:16 AM
9 inch rear
35 axle
lca relocation brkt
stock length
1/2 studs
full spool
4:30 gears
s60
rear oil
lca relocation brkt
1350 yoke
stock length
full spool
4:10 gear
c/m yoke
x2 !
Kaltech Tuning
03-06-2011, 07:35 PM
Responses sent.
spcearle
03-13-2011, 12:08 PM
looking for a quote on a 9 or 60
96 z 4 chan
stock width
lca brackets welded
something close to 342s
i live in bk and can pick it up and way of getting any deal since shipping isnt needed....im in the army and getting ready to deploy in fall and wanna play with the car this year
spcearle@aol.com
Firebirdgm2000
03-13-2011, 01:42 PM
1999 Trans Am 6-Speed Twin Turbo
Moser 9" Stock Width & mounting locations for Lca's and Torque Arm
W/ABS & Traction 4-Channel
backing plates
Black Powder Coating
28 spline w/ Detroit TrueTrac 4.10
Fill & Drain Plugs Installed
Kaltech Tuning
03-13-2011, 06:54 PM
Quotes sent.
johns777
03-18-2011, 11:44 PM
2002 Trans Am A4
Moser 9" Detroit Locker w/ 35 spline axles
3.73 or 3.75 gear ratio
Stock width and stock studs
4 channel with new rings
Drain and fill plug
all brake line/cable brackets welded on
Ready to be bolted in
Also a PST driveshaft if you carry them
Thank you, John
Kaltech Tuning
03-19-2011, 09:12 AM
quote sent
J Rob 347
03-19-2011, 06:14 PM
hello i would like a price for
12 bolt for a 95 camaro
stock length no traction control
33 spline axles ready to bolt in
with the long 1/2 wheel studs
please quote with pos unit and
spool thanks
Kaltech Tuning
03-20-2011, 08:21 PM
Quote sent.
boydcoz71
03-20-2011, 09:40 PM
Price on a 12 Bolt and 9"
2001 TransAm
Desired gear ratio - 4:10
Stock width
Kaltech Tuning
03-21-2011, 07:30 AM
2001 TransAm
Stock width
PM sent
Busted 10-Bolt
03-22-2011, 05:59 PM
Two quotes please,
Quote 1)
9" housing & axle package
1" off each side
back brace
adj LCA brackets
using stock brakes (1994)
No ABS
spool, 35 spline
aluminum Daytona pinion support
1350 yoke
1/2 x 3" wheel studs
assembled center section, I assemble the rest
No powercoat
Quote 2)
Same as above but M9 housing + torquearm
Kaltech Tuning
03-23-2011, 01:00 PM
Quotes sent.
CorbinLR
03-26-2011, 09:57 PM
2000 Trans Am
35 Spline
Stock Width, Bolt Pattern and Studs
Sealed Bearings
Stock Brakes
4 Channel ABS 47 Tooth
Adjustable LCA Brackets
Kaltech Tuning
03-28-2011, 07:43 AM
2000 Trans Am
35 Spline
Sealed Bearings
Stock Brakes
I need a little more info. Which rear are you looking for? S60, 9 inch? What differential do you want? True trac, spool, etc?
Lightweight
04-04-2011, 10:00 PM
Is this GP still going on?
Kaltech Tuning
04-05-2011, 07:51 AM
Yes, this GP is a go. All orders must be placed by this friday 4/8.
Lightweight
04-05-2011, 04:36 PM
9 inch or 12 bolt....still un-decided. Want to keep my current aftermarket torque arm so that will be a factor
Year and model of the car: 99 M6 Z28
ABS: 3 channel
Desired gear ratio: 3.90's...31 spline
Desired differential: truetrac most likely...depends on the pricing, if 9 inch is the way to go would like aluminum center section
Stock width....ready to bolt in
RobsZ28
04-05-2011, 08:54 PM
98 Z28 A4
Strange 12 bolt
4 channel (ABS w/TCS)
33 spline axles
3.73 gears
Aluminum Diff cover
Littlemotor
04-08-2011, 02:17 PM
Year and model of the car: '99 Camaro SS
ABS? 3 channel (no traction control) or 4 channel (with tcs) : NONE
Desired gear ratio: 3:20ish (6spd car street car with big cubic inch and 91mm turbo)
Desired differential: Detroit True-Trac
EDIT: Highest available spline count for Ture-Trac differential. Also 1350 steel yoke on all quotes and an S-Series case with the Strange 9" please.
Please Price for STANDARD WIDTH direct bolt-in for FACTORY rear brakes. I'd like to see 9", 12bolt, and Dana 60 pricing.
Thanks!
jb7241986
04-13-2011, 11:04 PM
Never heard from kaltech i posted 3 months ago wow.
Kaltech Tuning
04-14-2011, 06:03 AM
I just looked back through the thread and don't see a post from you. What exactly are you looking for?
