New rear control arms from UMI Performance
Old 01-30-2010, 11:20 AM
UMI Performance's Avatar
Default New rear control arms from UMI Performance
Hello Everyone,
UMI has released two new styles of rear control arms for the 82-02 F-Body. Please take a look and let us know if you have any questions.
Made in the USA
On car adjustable lower control arms- rod end/polyurethane bushing combination
On car adjustable lower control arms- Roto-Joint/polyurethane bushing combination
Old 01-30-2010, 09:33 PM
DaddySS's Avatar
Those look like really nice pieces - nice job!!
Old 01-30-2010, 09:36 PM
SS DNA's Avatar
How noisy are these Roto joints ???
Old 01-31-2010, 12:12 PM
SuperSport01's Avatar
Nice control arms. UMI = good sh*t
Old 01-31-2010, 01:54 PM
riceburnerZ28's Avatar
It would be nice to have another discount at Speed inc open house
Old 01-31-2010, 01:58 PM
Breathing Fire's Avatar
Damn it! I just got poly/rod single adj. and then the roto comes out. Now an on car adj. rear arms? Damn it. Well looks like the old bird might get the ones I just got so the TA can have these. Nice!
Old 01-31-2010, 07:45 PM
The Roto-Joint's aren't noisy at all. They are very tight with no movement.
We will be there
Old 01-31-2010, 07:52 PM
IROC-Z28_CAMARO's Avatar
They look good. They rebuildable?
Old 01-31-2010, 09:09 PM
Striker's Avatar
What are the benefits of double adjustable arms vs the ones above? Im debating between the double adj roto's and the poly/roto's as posted above.
Old 02-01-2010, 12:41 AM
SS DNA's Avatar
We will be there
I had my mind set on Poly Poly because I had a Poly-Rod setup before and I didnt like the noise it made. Made ladies ask me why the noise was happening
But if the Roto joints are quiet, I might go for these.
Old 02-01-2010, 06:40 AM
Yes, the Roto-Joints are rebuildable (If this is ever needed) and the polyurethane bushings can be replaced if ever needed as well.
If you still have those control arms with the rod ends we can sell you a Roto-Joint to screw in the rod ends place. If not the Roto-Joint works very well, it is very quiet and street friendly. I think you would be very happy with them.
The control arms above with the Roto-Joint will be a little more street friendly. This is because the have a polyurethane bushing on one end with absorbs the road noise... they are also less expensive. The double Roto-Joint is also street friendly but since there is no polyurethane bushings the rid could be a little stiffer. The Roto-Joint on both ends would perform better in autocross type driving.
Old 02-01-2010, 12:08 PM
SS DNA's Avatar
I ended going back to stock and sold my LCAs
Old 02-01-2010, 04:20 PM
Time for new control arms
Old 02-02-2010, 06:42 PM
SantaCruz163's Avatar
How is the strength with there being two joints at one end?
Old 02-03-2010, 07:25 AM
UMI Sales's Avatar
Hello
I take it you mean 2 adjustment options. Everything that we use is hardened and zinc plated to not only maintain superior strength but also protect the product itself. We have not had any issues strength wise. If you have any other questions feel free to ask!
Thanks
Brad
Old 02-03-2010, 09:08 AM
Like Brad had mentioned many of our items are hardened for increased strength. The adjuster in the center, threads and threaded tube adapters are all machined from 4140 chrome moly. The adjuster is heat treated for additional strength and 4140 is chosen on the threads for increased durability. Overall many of these items are overkill for there application.
Hope that helps,
Ryan
Quick Reply: New rear control arms from UMI Performance
