Grinding during light throttle cruising
Old 01-31-2010, 04:41 AM
Tommyv8's Avatar
Default Grinding during light throttle cruising
This problem has persisted since I dropped in a 3.42 rear from a 6-speed a few months ago. It was hardly noticeable at first but has gotten worse. On the highway I can hear and feel a grinding at very light throttle. It goes away if I step on the gas a little harder or if I let off completely. It has always whined a bit but the grinding is a lot more annoying to me. Any ideas as to what's going on here? I still have my original 10 bolt with 2.73 gears and 180k+ miles which worked fine, but I'd rather not have to swap it back in.
Old 02-03-2010, 04:05 PM
CodyZ28's Avatar
ya mine did that, and it finally broke about a month ago after about 2 years of the same grind. I havent even opened the case up yet. good luck
Old 02-05-2010, 02:52 PM
Tommyv8's Avatar
Did it break at the dragstrip or just while driving around normally?
Old 02-05-2010, 03:47 PM
hlaalu's Avatar
how loud is it? the one i just swapped in has a very faint "hum" when i barely touch the gas to keep speed up. happens around 50mph. Everything looked fine when I had it apart, I think these gears just make a little noise. Do you have any leaks?
Old 02-06-2010, 12:23 AM
CodyZ28's Avatar
Driving home and shifting it hard into 2nd lol
Old 02-06-2010, 08:47 PM
Tommyv8's Avatar
No leaks. The whine is of a moderate volume while accelerating. It's really the grinding that is annoying and kinda concerning, it wasn't that loud at first and now it makes me wanna tear my hair out. I guess I'll just have my original one rebuilt with 3.42 gears and throw it back on there. Or maybe I'll try to break this one first; Hoosier DRs and a Yank SS3600 or 4000 sound like a good idea.
Old 02-06-2010, 09:17 PM
massls1guy's Avatar
I had a metal on metal noise that got progressively worse. It ended up being a bad axle bearing. The axle bearings and seals are the easiest thing to replace, probably worth giving it a look.
Old 02-06-2010, 09:48 PM
hlaalu's Avatar
Well my old rear was so loud, I heard it over my dumped exhaust, turned out to be a bad pinion bearing.
Quick Reply: Grinding during light throttle cruising
