All T56's Created Equal?
Old 02-01-2010, 05:08 AM
TipsyMcStagger's Avatar
Default All T56's Created Equal?
I'm in the planning stages of a LSx swap into a Fox body Mustang. I'd like to go with a manual transmission so the T56 seems like a logical choice.
I don't know too much about the T56 though and don't want to get burned while shopping. Are there any years to be avoided? If so, is there an easy way to visually identify the units which are undesirable, inferior or incompatible?
Is there a list or "Sticky" that indicates all of the years and vehicles that came equipped with the T56?
Also, what bellhousing should I be looking for?
Basically looking for a little T56 101.
Thanks!
Tipsy
Old 02-01-2010, 07:19 AM
85MikeTPI's Avatar
Stay away from '93-'97 LT1 version T56s, and Corvette and CTSv T56s, they won't fit without alot of modifications. Just about any Fbody '98-'02 LS1 T56 version will be fine, and only slight updates over the LS1 span years. The GTO T56s will fit also. They have better synchros, but a wider gear ratio than the Fbody.
Old 02-01-2010, 08:51 AM
dustiebutt's Avatar
Exclamation
AND.....if you don't want to get burned, don't buy one off Ebay unless it's new with warranty!!!!
Old 02-01-2010, 05:59 PM
DVS99TRANS's Avatar
+1 to that dustiebutt. Build the t56 for the power rating you are going to go with. Don't put a 600whp LSx motor with a stock fbody t56 in it for sure. You will bend the 3-4 shiftfork very quickly. Also, just get a bell for a 98-02 fbody, they are all the exact same no matter what year. People do selling them on here in the classified section from time to time for a decent price. Keep an eye on that if it helps
Old 02-01-2010, 06:16 PM
squalor's Avatar
I have one in my 93 RX7. I'm using the 7/8" Wilwood clutch master cylinder and a extended hydraulic line.
The advice I want to add to this thread is this; Do not over extend your slave cylinder. Doing so will cause it to ingest clutch dust and greatly shorten it's lifespan.
Once your swap is drivable, set up a stop behind the clutch pedal to limit travel to only the amount you need to shift cleanly.
Old 02-01-2010, 06:59 PM
Great info...Thanks!
Is there an easy way to visually identify the '93-'97 LT1, Corvette (all years???) and CTSv's T56's?
I would think it would be easy for a seller to claim the tranny came out of an F-body if the buyer doesn't have a discerning eye.
Tipsy
Old 02-01-2010, 07:28 PM
357i's Avatar
Makking a LT1 t56 fit isnt that big of a deal, just 3 parts, the 4thgear/input shaft, bellhousing and "face plate" The input shaft is shorter, but i dont think there are any identifying marks the differenciate(sp) them.
Old 02-02-2010, 12:43 AM
jb98camaro's Avatar
couldn't you get pictures of the serial numbers or somethin? just a thought..
Old 02-02-2010, 10:31 AM
How exactly would that help?
Do you know a way to determine which vehicle the transmission came from by decoding the serial number?
Tipsy
Old 02-02-2010, 12:08 PM
BALLSS's Avatar
...while there are many sources for the info you want....ping D&D Performance (sponser to this site) and discuss specifics with them
..look into the T56 "magnum" for your application.
Old 02-02-2010, 01:05 PM
Thanks...but that's way more than I want to spend. I'm just doing a cam and intake. Not making any kind of crazy power. I don't need a "built" T56.
A stock T56 in good condition will be fine.
Tipsy
Old 02-02-2010, 01:41 PM
lavoy's Avatar
D&D is where i got my t56, its supposed to have all the mods needed to handle 550 ftibs. However that is probably when used in a standard weight F body, since my car is roughly 1000 ibs lighter i would imagine the tranny can handle a little more then that.
Old 02-02-2010, 03:29 PM
jb98camaro's Avatar
well i think there should be a way of looking up the year of the production through the serial number.. maybe through the dealer.. im not positive im just thinkin of ideas for ya
Old 02-02-2010, 08:39 PM
85MikeTPI's Avatar
Tipsy
Fbody's will all have this tailhousing, CTSv, Corvette's, etc. will not.
LS1 type front plate. Notice center area with 2 bolt holes to mount slave
LT1 type front plate. Notice center area with sleeve and single bolt hole at 4 o'clock where clutch fork pivot mounts
Old 02-02-2010, 08:42 PM
DamianN.'s Avatar
yea through the dealer for sure
Old 02-03-2010, 12:44 AM
jb98camaro's Avatar
ya thats what i was sayin! lol
Old 02-03-2010, 03:24 AM
Thanks a lot 85MikeTPI!
Tipsy
Old 02-03-2010, 01:02 PM
jonathan_ed3's Avatar
I have heard this before...maybe from you on the RX7 forum. I feel this is a very important point you're making.
How do you know if you're over-extending the slave cylinder or not?
Old 02-06-2010, 02:59 AM
squalor's Avatar
My clutch released at the top; I only had to push the pedal in about an inch or two to get the clutch to release. Being the n00b that I am to swapped cars, I was pushing to the floor. Pretty soon, my brake fluid was turning dark, my clutch rez is connected to the brake master. They share fluid.
There was debris, like dead skin floating in the fluid. Pretty soon it got hard to get in gear. The car now sits in my back yard while I get ready to pull the trans.
Old 02-06-2010, 06:11 AM
FTSS's Avatar
Thumbs up
Originally Posted by 85MikeTPI;12838297[B
LS1 type front plate. Notice center area with 2 bolt holes to mount slave[/B]
Thanks, you can hear this stuff several times but your pics really drive home the basic difference and demystify the different slave styles. I'm linking this thread on another forum too, so thanks from them too.
Quick Reply: All T56's Created Equal?
