suspension problem after install, please help!
Old 02-06-2010, 09:08 PM
01Blk*SS*'s Avatar
Default suspension problem after install, please help!
hey guys, i just finished installing my stranos and koni 4/4s, but i have a problem. when i pulled the car out of the driveway i can hear a little clunk in the front when i come to a stop. I think its that i didnt tighten the top of the shock enough when the spring compressors were on. i only tightened them so there was five threads above the nut ( thats how the stock ones were when i took them off). Do you think this is the problem? when the spring are clamped with the spring compressors, how do you know how much to tight the top of the shock? please help guys, i want to try to fix this in the morning!
Old 02-06-2010, 09:13 PM
1BADTALS1's Avatar
i did the same. also forgot the isolator plate that goes in between the upper mount and the strut tower..
i used a deep socket and air gun and i put it down as far as it would go.. the second time.. haven't had a problem yet..
Old 02-06-2010, 09:16 PM
01Blk*SS*'s Avatar
lol i didnt put the lower plate on the first time, had to take it all apart. i hate the spring compressors btw!!!! so you think i should compress the spring all the way so the nut can tighten down all the way? thanks for the reply!!!
Old 02-06-2010, 09:18 PM
01Blk*SS*'s Avatar
also, did you use the big fender type washers that came with the front shocks? or do our cars not need them....
Old 02-06-2010, 09:44 PM
ThoR294's Avatar
the big flat washer? that goes on the strut itself. between the strut and the strut tops
Old 02-06-2010, 09:48 PM
01Blk*SS*'s Avatar
Yes the big flat washer. By strut tops do you mean the rubber piece you take off the old struts?
Old 02-06-2010, 09:51 PM
1BADTALS1's Avatar
you don't have to compress the spring to tighten it just let the air tool do the work.. it will still tighten it down. run the nut down till it stops.. should be good to go.
Old 02-06-2010, 10:21 PM
01Blk*SS*'s Avatar
i would use air tools if i had them :-(
ill be snugging it up in the morning, thanks guys!
Old 02-06-2010, 10:53 PM
Pontiacerator
RevGTO's Avatar
Yes, you need the washer - it goes on top of the shock - and tighten it with the spring compressed.
Old 02-07-2010, 02:01 PM
pjb
pjb's Avatar
That is WRONG. Tightening the top nut WILL NOT compress the spring and allow the top mount to be fully seated on the shock shaft. You will end up with the clunk sound a lot of people say they have when they don't compress the spring.
And yes, you need the big flat washer. It goes on first, the top mount next, and the isloator inside the mount next.
Old 02-07-2010, 02:07 PM
01Blk*SS*'s Avatar
got the washers in and the top of the shock tightened! no noises!!! thanks guys!
ps. i compressed the spring and then tightened the top of the shock.
Old 02-07-2010, 02:09 PM
pjb
pjb's Avatar
Cool!
good job doing it the right way. listening to the people saying you don't have to compress the spring will have you doing it twice.
Old 02-07-2010, 06:39 PM
01Blk*SS*'s Avatar
lol or me not doing it the right way, forgettting to put pieces in, having to do it three times hahahaa
