Which rods are stronger?
The Eagles:
http://speed-eng.com/store/eagle-rod...in-p-6678.html
Or..
The Compstars:
http://estore.websitepros.com/2120533/Detail.bok?no=82
on eagles website, It said that with the L19 bolts they are rated for 1400hp.
I dont know about the comps
Or..
The Compstars:
I am rebuilding my motor for my turbo build. I am going to be running between 700-800rwhp and try to get up to 900-1000 later on. I am Keeping my stock crank (347) and want my compression ratio around 9-9.5:1 I think. I am going to be running a multi-stage boost controller and probably a quick spool valve also, so I can run no boost or 20 lbs of boost and every where in between.
