used flywheel
Old 02-09-2010, 11:05 PM
Raptor_WS6's Avatar
Default used flywheel
i know its good to have a used flywheel turned, but is it a good idea, i mean will i need to shim it, and what do they mean by "shim it"
Old 02-10-2010, 10:40 AM
SPEC-01's Avatar
If you have an original stock flywheel, that has never been turned before then you can certainly have it resurfaced. Do not remove more than .015" though as this will make the flywheel overly thin and as such can affect clutch release. Shiming can be done though i do not suggest shimming the flywheel because this will affect the location of the ring-gear.
What clutch are you planning to you? I ask because our clutch kits include a .115" shim that is intended to be istalled behind the slave-cylinder though this is not relative to using an overly thin flywheel (it is used as a result of our clutch assembly having a lower stack height than the stock parts). If you need a shim let me know, they cost $5. You can also take a look at the link below relative to measuring to insure what shim thickness you need.
https://ls1tech.com/forums/manual-tr...need-shim.html
Let me know if you have any further questions. Thanks,
Old 02-10-2010, 10:21 PM
Raptor_WS6's Avatar
i have a ls7 clutch i bought used and it is a ls2 flywheel. never been turned
Old 02-11-2010, 10:51 AM
SPEC-01's Avatar
If you remove the minimum amount of material from the flywheel (.015" max) you shouldn't need a shim for this. One thing to keep in mind though is insuring that you have the appropriate parts. If you are using an LS7 clutch then you need a flywheel with a recessed friction surface. Make sure that your flywheel has this, otherwise the parts won't work together. Let me know if you have any further questions. Thanks,
Old 02-11-2010, 10:22 PM
Raptor_WS6's Avatar
yes, its the flywheel that the guy i bought it from used. ok, so i tell the guy to take off as liil as possible and not to exceed the .015" right?
Old 02-12-2010, 09:00 AM
SPEC-01's Avatar
Yes...that is correct!
Old 02-13-2010, 01:14 AM
02CamaroSSLE's Avatar
that is a awesome write up!!!
Old 02-15-2010, 08:24 AM
SPEC-01's Avatar
Thanks!
Quick Reply: used flywheel
