Drag Racing Tech
Wire hole for line-loc in firewall
Old 02-10-2010, 10:05 AM
Intercooler2's Avatar
Default Wire hole for line-loc in firewall
So I got the SLP kit in but read how they want you to route it up the passenger side and over. Any hidden holes or better way to do this without it becoming a PITA?
Old 02-10-2010, 10:20 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Mine is routed though the Passangerside fire wall, no big issue. There is a hole for the throttle cable on the driver side and there is one for the harness but unless the car is gutted, it would be next to impossible to get the wire through. Just put it in/near the ashtray, route wires either under carpet to the kick panel area of the passanger side or up and around the HVAC side. then route down to the nose and under the radiator support.
You bearly notice it.
Old 02-10-2010, 05:14 PM
Zmg00camaross's Avatar
There is a access hole under the pcm on the passenger side.
Old 02-10-2010, 07:17 PM
NHRAFORMULA00's Avatar
Pull it through with a coat hangar,where the pcm wires go through.
Old 02-10-2010, 09:11 PM
DiabloFormula's Avatar
I drilled a hole on the drivers side under the big square C100 plug, ran all my nitrous, line lock, 2 step, etc wires though that then just put the right size rubber gromett in it to keep the wires from rubbing.
Old 02-10-2010, 10:47 PM
promod1955's Avatar
X2. I run wires under this plug as well. take the panel off under the dash and its pretty easy to drill
Old 02-11-2010, 01:35 PM
Grommet from NAPA or something?
Old 02-11-2010, 03:20 PM
Yup, you can get them in ***. packs, all differant sizes.
