All New 415 Gen IV Iron Shortblock Direct LS2 Replacement $3299.99
Old 02-11-2010, 05:15 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
Thumbs up All New 415 Gen IV Iron Shortblock Direct LS2 Replacement $3299.99
This is a direct replacement for the LS2 or Gen IV style engine.
New Gen IV Iron Block Usually a $300 option
4" Stroke Forged Crankshaft Add $300 for a 4.125" Stroke to make it a 427
4.065" Forged Pistons Add $300 for 2618 Forgings
6.125 H Beam Connecting Rods
ARP 2000 Rod Bolts
Forged Flat Top -4cc or -25cc Pistons
1.5mm Power Pack Ring Set
ACL H Rod & Main Bearings
Digitally Balanced Assembly
Fully Assembled & Blue Printed
Old 02-11-2010, 07:20 PM
zssman's Avatar
What kind of boost will this engine(427 cubes) handle. Lookin for something that will handle a f1r, max effort. Thanks. Phil
Old 02-12-2010, 08:11 AM
LS1TECH Sponsor
Phil,.
I would recommend you go with a 4"(414.6 cuin) or 4.030"(420.9 cuin) bore for that combination.
It will be $3899.99 for that combination.
Old 02-13-2010, 08:27 AM
flatchat's Avatar
what can you do a 408 or a 383 for.
cheers
Old 02-13-2010, 08:46 AM
LS1TECH Sponsor
cheers
A 408 Iron would be the same price. $3299.99 A 383 Iron would be $2999.99
Old 02-19-2010, 09:15 PM
mystic98ls1's Avatar
what about a stock crank 370
Old 02-21-2010, 10:27 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
What would the cost be for this to be an aluminum block? I don't want to add any weight to the front end and don't need the benetis of iron.
Old 02-22-2010, 11:58 AM
LS1TECH Sponsor
It is $4489 for the aluminum 415 option.
Old 02-22-2010, 02:53 PM
UNDER PRESSURE MOD
WOW, I didn't think it would be a $1300 difference.
Old 02-23-2010, 02:29 AM
zssman's Avatar
Default motors
Originally Posted by Schwanke Engines
Phil,.
How much for a alum. version of this, and do u think it would handle the boost and last? Thanks for the replys.
Old 02-24-2010, 08:24 AM
LS1TECH Sponsor
http://schwankeshortblocks.com/Short...rt%20Block.htm
http://schwankeshortblocks.com/Short%20Blocks.htm
LS1TECH Sponsor
+ the add ons already mentioned
Quick Reply: All New 415 Gen IV Iron Shortblock Direct LS2 Replacement $3299.99
