Need help on putting my ls1 in!
I own a 1999 trans am and i pulled the engine out to swap it for a new ls1 and i can't remember how the engine harness wires go back on and what brackets go were and wat bolts go to wat. Need as much help as possible and asap! Thank you!
Wires are easy..lay them out on their proper side and everything will pretty much line up.
As far as the Accessories go..here is a decent pic..
Power Steering Assembly is there on the upper corner, below that is the Alternator. I don't have AC, but that is on the other side down low.
start with the fuel injectors. They are all numbered on the harness, 1 2 3 4 ect.... After you get them all lined up the rest is easy. If it reaches its where it goes. They wont fit in the wrong place.
