need help with stand-alone engine harness
i posted this in the electronic section but figured a lot of guys here did this whole "race car wiring".............
Next on my build is my electronic section. I want to have the PCM a stand-alone unit for the engine and then hard wire the car for headlights, tail lights, turn signals etc. For the engine harness what all sensors do i NEED? Im running SD (boosted motor) and a 2-bar MAP. If i run open loop, or which ever doesnt use the o2's for referance, can i get rid of the o2 wires out of the harness? Also ill have autometer water, oil gauges so can i not run them sensors also or will it play games with the PCM? Basically i want to run the bare minimum wires and use the PCM as a stand-alone unit mounted inside the car. And will the PCM need anything from the body harness to work as well? Like anything from the gauge cluster? Sorry for all the questions but this wiring part is a whole new ball game for me. What do you guys think?
*edit* also running a RMVB th350 so i dont need any trans plugs either, and running a a1000 fuel pump so no fuel relays or wires eaither, only for the fuel gauge for my cluster
just remove everthing and wire in each circuit individually for the chassis.
for the engine:
if your running in open loop you can lose the 02 sensor wiring...
oil pressure you can lose...(cluster)
low oil level
maf
iacv
alternator wire. (cluster)
all smog.
knock sensors
what you need is, crank signal, cam signal, injector plugs, tps, map , coil packs wiring and coolant temp.
for the engine:
low oil level
maf
iacv
all smog.
knock sensors
im not too sure. not sure if im imagining things, but i thought that i read up if the coolant sensor isnt plugged in, that the engine will not run right.....i dont remember exactly tho. hopefully someone will chime in on that to clear up that question
you gotta have the coolant sensor for the pcm becasue it bases your fueling tables off of it,i did this to my car with a modifed 12 circuit painless chassis harness and then rewired the pcm as a standalone harness the best thing is have the factory manaul sit down and highlight all the uneeded emissions knock sensor,02's if your not using them like said above cam,crank,coill,injectors,iat,map,and coolant temp are needed along with the fuel level wire from the sender to pcm for everything on the cluster to work,also that serial wire goes to the obdII conn,along with a power and ground.,off the top off my head i think its purple,wire,you can also use the fuel pump trigger from the pcm to trigger a relay on for your a1000 it supplys a ground signal and is enough to signal it, .off the pcm there is a serial data line that will feed your cluster for the speedo,oil psi,fuel level water temp,i belive kurt urban sells a oil pressure port so u can use the stock oil psi sender and a mechanical gauge,also for the cluster you need a power,ground,and illumnation witch you can pick up right off the headlight switch for a short wire run,take the cluster out and use flat black paint on the cluster board to get rid of your abs,air bag service vehicle soon lights,the speedo is i think a green wire off the pcm down to the speed sensor the serial wire handles just about everthing in the cluster,i used just the stock alt wire for gen L on the pcm and alt.and a 8 gauge wire back to my shut off switch i layed out the engine harness on the motor and shortened and extended wires as i went for aclean look.lengthened the wires on the pcm to goinside the car along with my coils under the dash with the pcm wires coming out where the back of the intake is on the firewall make sure you keep both sets of injector power wires and also the grounds on the back of the heads,i was able to make a bracket where i cut out my fender aprons to mount the chassis harness and hide the wires for the headlites and fans in the core support if i think of any thing else ill let you ill try n get sm pics up theres almost no wires visible in my car hope this helps
holy crap spaulding, thats a lot of **** there that i couldnt follow, lol. Sounds like a lot more then i wanted to do. I wanted to ditch my cluster and replace it with all autometer gauges anyways so ill just do that. So now with that being said that will make it more of a engine harness and i wont need to run wires all over the place to run the cluster correct? The computer wont need any signal wires from my a1000 then right? I wont mind running the temp wire i guess but can i ditch the knock sensors in the valley cover?
I have a good friend that makes/modifies wiring harnesses for LS swaps and people like me that just want to get rid of all the unnecessary crap. He charges around from $3-500.00 depending on what you want done.
Let me know if you would be interested in having something like that done.
that is what i did with the harness in my firebird and it was actually pretty easy. only tookme a few hours one night. just use the pin-outs from the FAQ's in the conversion section. piece of cake. i kept my o2's and stuff but was still able to eliminate around 50 wires.
ya Phil, i tried that with my lt1 harness and it was HORROR! I have NO patience for that ****, lol. Id rather pay a few bucks for one already done and plug-n-play. Im getting tired of moddin stuff, just want the car done.
BTW i still have them 241 heads chillin here =)
yea i would deff be interested just not right this second. Does he need a harness to mod or can he make me one from scrap? I found a guy on ebay who makes them from scrap for around $400. I just want bare minimum for plugs and wires so im tryin to find out here what i absolutely NEED. It will be ran in open loop SD so no o2's.
