Drag Racing Tech - How fast did you take your FACTORY Torque Arm?
EHat911
02-15-2010, 12:37 AM
Just outta curiosity i just wanted to see how fast some people went with their Factory Torque Arm time and 60ft and if you know your weight. my car was full weight with an iron block and it went 10.29 with a 1.39 60 at full weight i know this is prolly a stupid idea to go that fast with it but it worked it didnt break so. just wanted to see what the fastest time ever was on one of these were
slowredz
02-15-2010, 01:24 AM
6.0's in the 1/8th at 3400 raceweight
dnkynrbk
02-15-2010, 06:12 PM
full weight TA went 26 inch tall slick went 1.42 60ft and 10.23 1/4 mile with a 10 bolt 150 shot of spray.
Sofls1
02-15-2010, 06:19 PM
Full weight SS 1.45 60ft 10.57 on a 26X8.5 et street and still looking for more...:devil:
Tzion_ben_Arthur
02-15-2010, 08:45 PM
still mounted to tail shaft housing ???
BillyBob750
02-15-2010, 08:55 PM
I know of a guy whos been 4.90's with one.. Its in a third generation car though, so I dont know how much different they are from the fourth generation cars. I know a friend of mine tore up a factory torque arm with a bolton LS1 car.. *shrug*
358chevycamaro
02-15-2010, 09:40 PM
1.47's on the factory torque arm and 10-bolt N/A. Stalled A3 here...
Zmg00camaross
02-15-2010, 10:04 PM
Pretty sure thats flat getin it with a stock part, what was the rest of the setup in the rear? must be a autos also i would imagine.
358chevycamaro
02-15-2010, 10:11 PM
Stalled A3 here. Above post edited...
BMR Tech
02-16-2010, 01:57 PM
Had a customer running 9.90's with one but started to develop problems 30-40' out the torque arm would bend then spring back and unload the car :eek2:
Any questions just ask :D
AgFormula02
02-16-2010, 03:06 PM
5.56@125 with a 1.29 60ft
Took the TA off and welded a 1in pipe down the length of it and welded the front bracket up so it couldn't split apart and added a bar that went to crossmember to help not brake the tail housing. It was a stock ta though.
Ed Wright
02-16-2010, 04:20 PM
Still have one.
Sofls1
02-16-2010, 06:56 PM
Mine is, with a rubber bushing still too. I have been thinking about buying a crossmember though..
PowerShift408
02-16-2010, 07:21 PM
I went 10.60s on mine, in a stalled A3. This was quite awhile ago though.
BMR Tech
02-18-2010, 08:48 AM
WOW that's pretty impressive that tailshaft housing has held in there:hail:
mike c.
02-18-2010, 02:54 PM
Mine broke early. It did not like slicks.
kline454
02-19-2010, 10:33 PM
i went 10.6s 1.46-1.48 60ft full weight lt1 with stock everything on the suspension no front sway bar,on a 28x10 tire.
9sec93
02-20-2010, 02:22 AM
racecar!!!
kline454
02-21-2010, 10:57 AM
racecar!!!
Yes that is a racecar in your sig.......:D
1_bad_TA
02-21-2010, 11:47 AM
I got to see a video of this. That is straight flyin for a stock arm. 8's on a stock arm is nuts.
