What Front Brakes do you suggest
Old 12-26-2003, 05:53 PM
Scoobie's Avatar
Default What Front Brakes do you suggest
While in the process of doing shocks/springs/suspension mods im also saving for some big front brakes.
Im looking for some new rotors/calipers that will not only look great but perform well too.
Im looking for a daily driver set up, nothing too extreme. Thanks
Scoobs
Old 12-26-2003, 06:12 PM
mitchntx's Avatar
A C5 conversion will set you back about $800
A Wilwood kit will run about $1600
A Stoptech or Movit kit will be just over $2000
After that, you begin to get expensive!
Old 12-26-2003, 07:16 PM
Jpr5690's Avatar
I Always Liked The Drilled Look If It Were Me Id Do Some Drilled Slotted Roators Paint The Calipers And Do Some Better Pads... It Will Look Great Keep Cost Down And Peform A Good Deal Better Than Stock Which Is Not Too Bad For Street Use....
Old 12-27-2003, 02:54 AM
BlackWS602's Avatar
The only problem I have with drilled rotors is that if the holes aren't part of the casting process they WILL end up cracking. Honestly I would just look into the C5 or Z06 upgrade. They may be one and the same I'm not sure. I'm looking for the same thing you are and I'm wanting something I know will be there for me when slowing down after a 10 second run. I've thought about Wilwood but then thought maybe a vette upgrade would be perfectly fine
Old 12-27-2003, 04:30 AM
roy
roy's Avatar
Scoobie what poison do you like ? drag race , hot laps , etc.
Old 12-27-2003, 01:23 PM
Scoobie's Avatar
Mostly just daily driving, but its a 1LE car that sees both the 1/4th and the Auto X. The car runs about a 12.00 right now. I also want something that stands out appearance wise too for shows.
Old 12-29-2003, 09:33 AM
Xsta Z 28's Avatar
For a cheap - easy, AND a cheap - easy system to maintain, the C5 conversion is the way to go. Other than the brackets, the entire system can be maintained with autopart store parts - or the dealership. But I'm partial . . . .
Pics of the conversion in the sig.
Old 12-29-2003, 09:35 AM
It's not mine! woo hoo!
demonspeed's Avatar
haha I just prefer my stock calipers with powerslot rotors and hawk pads. Works well for me
Old 12-29-2003, 09:45 AM
Jpr5690's Avatar
good point
Old 12-29-2003, 10:42 AM
mitchntx's Avatar
Very good point.
I found that my stock calipers would fatigue, though. After numerous heat cycles, the ears would flex ever so slightly causing a "long pedal". As I would engage the brakes, the pedal would slowly go down as the calipers flexed apart.
Consequently, the pads would taper and my pad contact surface was significantly reduced.
The C5 caliper is not nearly as susceptible to this phenomenon.
Old 12-29-2003, 03:09 PM
WILWAXU's Avatar
Originally Posted by mitchntx
Very good point.
Interesting you should say this...
I noticed this weekend that the Z06 calipers have a much narrower mounting tab than the stock f-body calipers.
Old 12-29-2003, 03:18 PM
BlackWS602's Avatar
Mitch what would you suggest as far as a good brake upgrade goes? I'm looking for something that is good for the track and offers a good reliable quick stop. Also appearence comes into play alittle also
Old 12-29-2003, 05:20 PM
Xsta Z 28's Avatar
Question
Another question - How much do you want to spend?
Old 12-29-2003, 05:28 PM
mitchntx's Avatar
Just to clarify ...
I'm talking about the ears on the front of the caliper, where the pad rides. As you press the pedal and force the pistons out of the caliper, the ears I'm referring to are just opposite the pistons.
The mounting tabs are not the ears I was referring to.
After driving my Prospeed shod car for a while and then driving a Firrehawk with the C5 brakes, I was amazed at the difference in stopping power Simply amazed! And the Firhwak owner who drove my car was equally amazed.
There is that big of a difference ....
Old 12-29-2003, 05:36 PM
BlackWS602's Avatar
Not looking to spend an arm and a leg. I'm not a road racer or anything. Just wanting a good brake system that puts out better stoping power and will be there for me on hard braking after a 1/4 mile run
Darkhalf's Avatar
Just curious what caliper does the Movit kit use? ST-40? Big Red?
Old 12-29-2003, 05:39 PM
Darkhalf's Avatar
I think the C5 would be your best bet. The C5 kit is probably a nice upgrade from stock, I'm sure mitch will say the same thing.
Old 12-29-2003, 05:40 PM
BlackWS602's Avatar
Right now that's what I'm thinking. If I went with anything else it would probably be Wilwood.
Old 12-29-2003, 05:46 PM
WILWAXU's Avatar
Stock brakes have no problem doing that..
Old 12-29-2003, 05:48 PM
mitchntx's Avatar
www.movit.de
Before anyone pulls the trigger on a brake upgrade, make sure you can live with the cost of expendables. Sometimes brake pad cost and availability is eye opening!
